Le37r88 Samsung 37
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Le37r88 Samsung 37
    Hi a bit of advice,yet another faulty Samsung set,on switch on had a haze/fuzzy image on left of the screen,this disappears and the screen stays blue.
    The remote don't seem to work well with the set either (do these need programming to the set ) original Samsung one,also when TV is in its blue screen state the left side speaker crackles loudly,any ideas.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Le37r88 Samsung 37
    Probably failed epprom these r88bd's I have seen the epprom fail so many times which causes lots of glitches but it could also be other things causing the fault. Could you post pictures of the boards and of the fault please.
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Not opened it up yet,but will post pics,so is this new board job or can it be repaired,what causes the speaker to make this noise,
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        • LEEDASH
          • Dec 2012
          • 481
          • Bedfordshire
          • CapLeaker
            Leaking Member
            • 8146
            I see that your caps are leaking in the PSU. Fix what you know is bad and those are certainly bad. 3 brown ones on top.
            • LEEDASH
              • Dec 2012
              • 481
              • Bedfordshire
              Yes,one is bad and the other two are bulging,I've checked locally at a well known electrical store and they are not listing 470uf 25v,can I have slightly higher but not lower is this correct.
              • CapLeaker
                Leaking Member
                • 8146
                yep, correct. Higher in voltage no problem at all. Definitely not lower! Capacitance either same or a bit higher.
                • flocko
                  • Nov 2012
                  • 1121
                  If the local well known store is Maplin then don't bother, as they only sell general purpose Caps and you should know by now you need low ESR capacitor for this kind of job (241 posts)?
                  • LEEDASH
                    • Dec 2012
                    • 481
                    • Bedfordshire
                    So avoid maplins,only a suggestion as I only wanted the three,eBay have some but paying double for postage,
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Replace all the capxon brand capacitors with high quality brand caps like Rubycon, panasonic or UCC. Maplin do offer low esr caps but they are cheap and not as reliable.
                        09-07-2024, 05:50 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
                        Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 06:20 PM
