Backlight led strip replacement Samsung ue40c
  • Ice203
    • May 2015
    • 99
    • Uk
    Ue40c5100.
    Any know if there any other models that might have the same led backlight strip to fit this TV.
  • Ice203
    • May 2015
    • 99
    • Uk
    Re: Backlight led strip replacement Samsung ue40c
    Bump
    • nicke74
      Samsung UE55JU6875 issue after backlight replacement
      by nicke74
      Got problem with a samsung UE55JU6875 after replacemant of backlight
      I have done similar replacement several times before without any issues but now I got video problems after the replacement and do not understand why
      Attached picture of the problem
      Is it a bad panel or any issues with the T-con card or ribbon cables or bad connections?.
      I have tried to replace both ribbon cables from T-con to panel without any difference.
      Any ideas?
      The only misstake I might have done was forgot to remove the ribbon cables from the T-con card before...
      04-02-2023, 11:03 AM
      09-07-2024, 05:50 AM
    • ScHAmPi
      Samsung UE48JU7000 screen issue after backlight replacement
      by ScHAmPi
      Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
      I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
      07-15-2024, 05:41 AM
    • Xristakis795
      samsung ue55ju6800 change backlight strip
      by Xristakis795
      hi to all i want to change the backlight strip on the above model
      do you know if there is someone helpful video with similar model whith mine ?
      thanks on advance
      04-18-2023, 01:17 PM
    • howardc64
      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
      by howardc64
      TV was fixed just after removing Samsung's rear snap cover.
      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
      Maybe PSU->backlight connector didn't have a good contact?...
      07-23-2025, 12:34 AM
