Sony Bravia 40cx520 weird issues
  • math
    • Jun 2013
    • 9
    • australia
    https://youtu.be/jL8y-JpI2rY
    I have a sony bravia 40cx520 tv. thinking i could fix it with a board swap... problem 1. 3 red flashing light code.....
    1a. i get out my multimeter and test standby voltage... 3.3v
    2. i check every connection to the tv, all is good, no dust or corrosion, No damage to any capacitors or resistors or transistors/mosfets that's visiable
    Que> board replacement time, I replace, power board Same 3 red flashing light code... I replace mainboard... that's where things got interesting....
    1. I turn power on..... 0.1second of backlight, just a flash... 2. green and orange light flash at the same time and continue to flash every 0.5 seconds forever, with no breaks or sequence to speak of.... Any ideas ?
    See the video for a bit more info.
    I didn't notice any physical damage to the capacitors
  • Ihandyrepair
    4 red flash led 65X950G boot Sony and android logo but then black
    by Ihandyrepair
    HI guys
    I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
    here is the issue
    I have Sony and android logo. but then 4 led red flash lights front of the tv
    I have 3.3v ref. 12v reg then T con 12v when I press the power on button
    but then I get black screen and 4 red flash light at the front LED
    but I get 3 led flash on the LED driver board.
    I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
    so I tried...
    07-11-2024, 01:45 AM
  • JUCaESAl
    Sony bravia KD-65AF9
    by JUCaESAl
    Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
    Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
    10-20-2025, 04:03 AM
  • alegatorul
    sony bravia kdl-43w756c, no power, no sound
    by alegatorul
    the charger brick has 19,2-19,3 vcc
    changed the inverter board same result.
    where should i start?
    cheers
    11-15-2025, 10:00 AM
  • ekozeko333
    by ekozeko333
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
  • justin35
    Sony bravia kdl-43w755c - boot loop
    by justin35
    i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
    from what i read online it looks to be an emmc issue…
    i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
    i took out the board and say an samsung 16gb emmc
    i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
    i could try to put one instead of the 16gb one, but will it work?
    where do i get the software from?
    any help will be much appreciated!...
    03-06-2024, 12:26 PM
