samsung tv problem
  • carus
    • Jun 2015
    • wales
    samsung tv problem
    Hi I have a ps43d450 model TV. The problem is I changed somthing in the service menu which i think it was something called the t-con setting. And since i did that the remote want work with TV and there is no red light at bottom of tv. But the TV comes on and i get a picture. I tryed reseting the eeprom and the banner showed up which was expected to but it is up side down thats how far i can get with the TV its asking to press ok to enter service menu but the tv remote does not work with the Tv any more please help
  • victor_cj
    • May 2015
    • 90
    Re: samsung tv problem
    In this case you need to write the eeprom or the nand flash memory again with a programmer or service interface. You can try with a blank eeprom first.
    The art of fighting without fighting
    • Hamie
      • Apr 2014
      • 1383
      Try updating the firmware by USB.
      You should be able to do this without the remote.
      Either way it's important to update the firmware on this TV, without the most recent update installed the TV breaks down fairly quickly.
      • carus
        • Jun 2015
        • wales
        Thank you for your reply. How do I go about programming the eeprom or flashing it. Is there any tuts I can follow please. And as for updating the TV it keeps failing hence the reason why I went into the service menu.
        • victor_cj
          • May 2015
          • 90
          You need a programmer to read/save/erase the eeprom IC901(24C512) first. You can try to reset the tv set with SZW1201 that is not mounted.
          • gsoo
            • Oct 2013
            • Ελλάδα
            Subject:
            Search for FM24C512 EEPROM file for Samsung UE75AU9072UXXH (motherboard BN41-02844B)
            Message:
            I am looking for the FM24C512 EEPROM (.bin) file used by the BN41-02844B motherboard in the Samsung TV model UE75AU9072UXXH.
            I do not have access to a working board to backup, so if anyone has the file or can guide me how to find it, I would greatly appreciate it.
            Also, if you know of any techies or community that can help, please let me know.
            Thanks in advance!
            • gsoo
              • Oct 2013
              • Ελλάδα
              Αναζήτηση αρχείου FM24C512 EEPROM για Samsung UE75AU9072UXXH (μητρική BN41-02844B)
                09-07-2024, 05:50 AM
                LCD LED TV Service Menu Codes
                TCL LED TV Service Menu Code
                LG LED TV Service Menu Code
                10-31-2024, 03:58 AM
              • jesterace
                Samsung B2030HD IR Remote Receiver Dead, shorted micom?
                by jesterace
                I have this TV a small 20 inch that works perfectly except for the IR has stopped. I have confirmed that the remote control is fine and tried an alternative and even tried with IR blaster from phone. Remote 100% ok.
                Tried installing latest firmware but no change.
                TV won't respond to remote at all, not even to bring it out of standby. I have to use the touch sensitive front panel to operate, at which point TV is usable albeit with no remote.
                Tried replacing the IR receiver diode/bulb on front panel and no change so put the old one back. After tracing...
                10-26-2022, 02:20 AM
                09-06-2024, 11:40 PM
