Sunny LCD sound problem
  • necatduman
    • Feb 2015
    • 72
    • siirt
    serino good deeds friends : SN042L88001330 TV LCD TV MODELS SOUND PROBLEMS SOUND COMING TV SOMETIMES AN IMAGE occasional TIKIRTIL not in THIS IF THERE IS A PROBLEM THE PROBLEM experiencing HDMI and SCART
    DONE : TV SUPPLY VOLTAGE CONTROL HAS BEEN CHANGED loudspeakers are
    TPI 3110 COMING BUT BİRTÜRL the audio output of the voltage could not Haled
  • victor_cj
    • May 2015
    • 90
    Re: Sunny LCD sound problem
    Check or replace TPA3110D2 and the 1uF smd caps around him.
    The art of fighting without fighting
    • hugocarmo
      Panasonic TX-24A1UN CRT Sound and Input problem.
      by hugocarmo
      Hi.
      I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
      It is imaculate inside, almost no dust or debris inside.
      The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
      So I started to look for a service manual, I found one, and started from the beginning.
      Most of the times the caps are the problem so I orderer all the caps for all boards,...
      04-26-2025, 07:45 PM
    • computeka
      Macbook Air A2337 820-02016-07 No sound problem
      by computeka
      How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound....
      05-08-2024, 10:26 AM
    • Alija
      sound problem on my dell latitude 5300 2 in 1 laptop
      by Alija
      I have a sound problem on my dell latitude 5300 2 in 1 laptop.
      Sound was working on the laptop and I had 2 Intel drivers and one more. When I turn on a song on You Tube, there is no sound, I uninstalled the drivers and tried to install them again, but now in the device manager the sound card is not visible, it only has Intel HD
      Please help me
      08-02-2022, 12:31 AM
    • cazi1001
      Samsung Galaxy A22 - strange problem with sound / speaker
      by cazi1001
      I have a Samsung Galaxy A22 5G with a strange error image.
      If I have a call, I can't hear the voice of the interlocutor and he can't hear me.
      If I switch on the lower speaker, I can hear the interloutor through it and now, he can hear me too.
      If I listen music via Youtube, even the upper or lower speaker don't work.
      If I switch louder or quieter, the sign on the screen show me a headphone.
      If I plug a external speaker via Jack plug or USB-C, I can hear the sound.
      Does anyone have any ideas, what the problem could be?​
      02-10-2024, 09:16 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
