Samsung LN46B550 No Startup
  • Syryll
    • Jul 2012
    • 32
    I've got this Samsung TV laying around that doesn't work.
    Standby light comes on when plugged in, as it should. When I attempt to power the TV on, I get the power-on sound the TV makes, no backlight and the standby light flashes 5 times and goes out.
    I've read that Samsung TVs will power on the backlight if CN802 is disconnected when applying mains power. This isn't happening with this set. Not sure if this particular one has that "feature," but I figured it could be of note that I tried it.
    Two big caps in the center read 157.7 at the legs with TV in standby, 151.5-7 when powered on.
    CN802 readings:
    DET_5v: 0v
    INV ON/OFF: 5.15v
    13Vm: 12.99v
    13Vs: 13.04v
    5.3v: 5.17v
    STB 5.3v: 5.2v
    POW ON/OFF: 1.18v
    CN1806 readings:
    VCC 12v: 13.00v
    LD1: 12.76v
    LD2: 12.76v
    The power supply is marked as model IP-281609A
    How should I proceed?
    Re: Samsung LN46B550 No Startup
    "Two big caps in the center read 157.7 at the legs with TV in standby, 151.5-7 when powered on." The PFC Voltage booster circuit is not working.
    Check all the diodes in the section between the two big heatsinks, especially the DP805, 806 (I cannot read the numbers clearly).
    BTW, the board does have built-in pull-up resistors for testing the board when the cable between the power supply and the main board is discoonected.
    BN44-00265A
    http://www.shopjimmy.com/samsung-bn4...upply-unit.htm
    • Syryll
      • Jul 2012
      • 32
      I checked all the diodes on the board. DP805 and 806 are fine. The only one that tested bad was DM810, which resides under the legend for CM802.
        09-07-2024, 05:50 AM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
        Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
        This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-06-2024, 06:20 PM
