if i have 5volt but no other voltages isnt this bad main?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I get mixed up sometimes im still learning but I have 2 tvs and they both have only 5volt standby no other voltages and no bl_on so wouldn't this make it a bad main?
    Re: if i have 5volt but no other voltages isnt this bad main?
    Not always - if pson signal missing then yes if not then power board will typically be bad.
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • Capacitorial
      Powersupply has all the voltages - Monitor still no power
      by Capacitorial
      Hello guys,
      I have a Philips 240B7QPJEB. The monitor seems completely dead.
      I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
      On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
      The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
      The weird thing is, that the Power LED is powered over the TCON board.
      On The TCON...
      12-28-2024, 02:12 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
