Is BN44-00444A power supply from PN51D550C1F bad?
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    I got my hands on PN51D550C1F. I have determined that power supply is bad, as it is not giving me Vs or Va voltages. Also the Y sustain board was fried, as I have found a loose screw between the board and the panel with nice black burn mark on both. I assume that both YSUS and PSU failed because of the screw. Y driver board appear to be OK as well as ZSUS.
    I have purchased used PSU and YSUS. PSU arrived today. I have plugged it in, minus the cable that connects to YSUS and ZSUS boards subsequently, just to see if I get proper voltages. Va is within one volt of nominal but Vs is reading 245V where 207V is nominal.
    Technically speaking when you put a load on power source the voltage will drop. I am just not sure how true it is on TV power supplies or if it will drop that much that it will be nominal again when under load.
    Should I return it?
    Re: Is BN44-00444A power supply from PN51D550C1F bad?
    245V is very high, and it is unusual for it to be that high even without load. How confident are you that your multimeter is working OK?
    • Pioneerx01
      • Apr 2015
      • 241
      • US
      I double checked with my older and cheaper volt meter. It read 240V and other one re-read at 243V.
        You could use two 120V light bulbs wired in series to test Vs load.
        I use 230V lightbulb myself. works great because it can be run continuously to load the PSU with ~100W.
        • Pioneerx01
          • Apr 2015
          • 241
          • US
          It worked great. It took some creative wiring as I am in US (110V) and most of my lights are CFL or LED. Once loaded the voltage dropped to nice 208V (207V Nominal)
          Thanks, good trick.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
          • CMCM
            Russound CA4 Power Supply Repair
            by CMCM
            Hello Everybody,
            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
            The outputs marked 12v and 20v are all measuring only 1v.
            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
            The capacitors physically look clean (no bludgesor leaks) and...
            07-03-2025, 01:12 PM
