problem with psu in Samsung 32"
  • katinkapicinyke
    • Mar 2020
    • 12
    • United Kingdon
    Re: problem with psu in Samsung 32"
    Check DB801,DB802.
    Thank you! Both de-soldered and checked, appeared to be working correctly.
    • R_J
      • 9556
      Originally posted by katinkapicinyke
      Thank you, I can see no short on CP811, CP805 (took me some time to find, little SMD bugger!), neither on CP805, CM807, nor on CM814.
      The resistance between the two legs of CP811 is around 4.5K Ohm, give or take due to my meters tolerance.
      I suspect the transistor must be bad, (open). you should be able to find a NPN transistor to install just to try it.
      It acts like a switched, regulator for the M_VCC voltage.
      • katinkapicinyke
        • Mar 2020
        • 12
        • United Kingdon
        One of those moments in life, when one only has a PNP in hand...
        I found a TIP117 in my box of spares, could I just use that instead?
        • R_J
          • 9556
          You can not use a PNP where an NPN is in the circuit. It won't work.
          • katinkapicinyke
            • Mar 2020
            • 12
            • United Kingdon
            Understood, thank you.
            I've found a BD243B (NPN), would that be sufficient please?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              What is the part number on the existing transistor QB802 ? Is it metal or plastic backed and does it connect to a heatsink?
              Edit
              If it's a KSD526-D then BD243B looks suitable
              • katinkapicinyke
                • Mar 2020
                • 12
                • United Kingdon
                #27
                Edit
                Thank you, yes, it is a metal backed To-220 as far as I can tell with no heatsink attached (KSD526-D).
                • katinkapicinyke
                  • Mar 2020
                  • 12
                  • United Kingdon
                  #28
                  Reporting back here chaps, issue fixed with replacing KSD526-Y with a BD243B NPN transistor, the PSU is back in business!
                  All your efforts are greatly appreciated, thank you once again!
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    Thanks for the feedback.
                      09-07-2024, 05:50 AM
                    • howardc64
                      Samsung UN55JU650DF network/streaming problem
                      by howardc64
                      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                      07-09-2025, 12:44 PM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
