Samsung 58 inch plasma ribbons
  • adamp91gvm
    • Jan 2014
    • 706
    Hi all i have a 6 Series 58 inch samsung plasma and i need a ribbon set for it mostly from t con to bottom buffers
    Any idea where ill get them thanks
    Re: Samsung 58 inch plasma ribbons
    you will need to specify the exact model number, maybe someone has broken up this set and has them, although it will be quite hard to find them.
    • adamp91gvm
      • Jan 2014
      • 706
      Samsung 6 Series PN58A650 58" Plasma TV
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
      • porfyriadhs
        Samsung Plasma PS51D6900DS Bootloop
        by porfyriadhs
        Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
        Thanks a lot !!
        10-19-2023, 11:31 AM
      • ArMaaN376
        Samsung PS51E550 Plasma TV
        by ArMaaN376
        I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
        Opened TV cover & observed foll
        a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
        b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
        c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
        How to confirm Y -Buffer board...
        06-19-2024, 04:05 AM
      • CDNBrewer
        Samsung Plasma PN43D450A2D No Power
        by CDNBrewer
        Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
        This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
        I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
        When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
        03-02-2025, 04:59 PM
      • chazh
        LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
        by chazh
        This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
        I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
        The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
        09-01-2025, 08:56 PM
