50pg20 maldischarge
  • KevinCro
    • May 2014
    • 104
    50pg20 maldischarge
    I have been working on this tv for ages and I am not having much luck. I have replaced the smps and have purchased two ysus boards. I bought both ysus boards on eBay so I'm sure they all had the same problem. All the voltages coming out of the smps are correct. The only voltage that is off is the vy voltage. It's setting at -105 and should be -190 it will stay constant for a few seconds, then flash and go back to -105. None of the capacitors look bad although I haven't checked them with my esr meter yet. It's only letting me upload one pic at a time so I will post more after I transfer them from my iPhone to my computer.
  • KevinCro
    • May 2014
    • 104
    Re: 50pg20 maldischarge
    here are some pics of the boards
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Z-SUS board faultI would say--But check ALL the supply voltages, Vs, Va, VSC, -Vy, VZ-Bias first...
      TELEFIX
      • KevinCro
        • May 2014
        • 104
        I found a bad transformer on the Ysus. How do I identify the specs? None of the numbers seem to come up on google.
          How did you determine the transformer to be bad?
          Note, SMPS transformers are very reliable and they very rarely fail!
          • KevinCro
            • May 2014
            • 104
            I replaced the zsus to no avail. Also, Turns out I was wrong about the transformer. I checked the vy voltage and it appears that if I place my probes on either side of the resistor, I get the proper voltage readings. But if I place one probe to a lead and the other to chassis ground the reading is poor and fluctuates. I'm not sure if that matters or not. I consulted the service manual and the readings that I get when testing the buffer boards are off. They all seem to be lower than what they should be. I'm in the process of buying new buffers so I'll update this when they come in. Anything I should check in the meantime? Thanks for the help.
            • Hamie
              • Apr 2014
              • 1383
              Crazy throwing boards into a TV.
              You have measured the correct way for -vy.
              But what the vsc and zbais voltages?
              You may have bought a faulty z-sus.
              • KevinCro
                • May 2014
                • 104
                I disconnected the zsus board and there were no changes to the operation of the TV. It would appear that I did indeed buy a bad part. I'll straighten that out and post results.
                • KevinCro
                  • May 2014
                  • 104
                  New zsus from shopjimmy fixed the problem. Thanks for all the help.
                  • Hamie
                    • Apr 2014
                    • 1383
                    Great news
                    • KevinCro
                      • May 2014
                      • 104
                      It seems that fixing one problem just reveals another. I've posted a pic of what the screen is doing.
                      • KevinCro
                        • May 2014
                        • 104
                        I had a similar issue with another set and it turned out to be the ysus. Thoughts?
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Not a Y-SUS fault. a y-sus/buffer issue will give horizontal lines, not vertical.
                          Summit to do with the vertical address (COF) chips, their data-lines, or the tabs to the glass of the panel.
                          Check where the tabs containing the COF Chips attach via ribbon-plugs to the boards that run along bottom edge of the panel, check all of the ribbons to those boards.
                          You'll have to remove the ally heatsink along bottom edge of the panel. Take great care, those COF are very delicate, easily torn/damaged, and do not run set without heatsink refitted.
                          You May get lucky, but in my experience, vertical lines on Plasmas usually ends up being one or more of the COF chips and is unrepairable.
                          TELEFIX
                          • PlasMatt
                            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                            by PlasMatt
                            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                            09-20-2025, 06:50 PM
                          • dkneyle
                            Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                            by dkneyle
                            This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                            Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                            02-01-2022, 02:08 AM
                          • shamsudeen
                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                            by shamsudeen
                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                            07-19-2025, 07:14 AM
                          • legg
                            LG 42PC3 buffer output doesn't follow YSUS
                            by legg
                            LG42PC3D -UD originally with green lamp but no display or audio.
                            Owner says was working, then went 'pop'.
                            All 5V caps bulging. replaced.
                            All PSU output voltages within spec but -Vy is low on YSUS.
                            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                            eventually shorts DG. Replaced all 3 - -Vy now OK.
                            Y scan buffer test point does not follow YSUS output below -50V
                            Note: This unit seems to expect YSUS output to park at -Vy in between
                            drive signal pattern periods. A replacement drive signal board confirms this....
                            11-18-2021, 11:49 AM
                          • abhishekkumar1902
                            Huntkey HK340-72FP SMPS shut on load above 2 amps
                            by abhishekkumar1902
                            I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
                            I have checked the following:
                            1. All output caps are OK, and all output rails read correct voltages at no load
                            2. All output diodes are OK
                            3. NTC is ok
                            4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
                            5. No short in main switching MOSFET
                            6. All other components...
                            12-18-2022, 09:52 AM
