LG 50PG6010 - Cold Ysus
  • pic_whiz
    • Feb 2014
    • 36
    Hi All,
    Any help much appreciated with this fault.
    TV powers up OK - green LED on front of the set. PSU Voltages all correct and present.
    Xsus board - One of the two heatsinks is warm, the other is cool.
    Ysus board - All Heatsinks cold.
    Tcon board - Solid green LED.
    Replaced both YSUS and TCON so far - no change.
    Any ideas?
    Cheers,
    Matt
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • PlasMatt
    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
    by PlasMatt
    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
    09-20-2025, 06:50 PM
  • advant
    by advant
    02-03-2020, 12:25 AM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
