Samsung UN32EH4000FXZC - no audio with internal speaker
  • Karthanon
    • May 2012
    • 6
    Hello, all. Ditched the 50" plasma I had gotten from someone last week (bad panel../sigh) and now have a 2012 32" Samsung UN32EH4000FXZC that I brought in to test out. Picture is great and it accepts video from all inputs with no issues, but all I get for audio is a 'clicking' noise from the lower right side of the TV. Doing a diagnosis self test for audio gives nothing, and I don't hear the harmony sound when the TV turns on/off.
    I guess I can always attach some speakers to it (as it has a headphone 3.5" jack on the back, or go optical out to a soundbar or amplifier or something), but what's the most likely culprit - just blown speakers (they're tiny 10W ones, I think) or something else?
    Worth tearing apart to fix? (Sometimes my wife just accuses me of ripping stuff apart just to tinker..)
    Edit: Plugged in headphones to test the headphone jack...and the same clicking comes over it, so it looks like just an audio problem internal to the TV = I guess I could just use as video only thing (and pull out an amplifier/speakers from somewhere) instead.
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
    09-07-2024, 05:50 AM
  • jinu_j
    How to test Subwoofer Amplifier with only a multimeter
    by jinu_j
    Hi Folks
    Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
    Problem
    I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
    Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
    Any advice would be appreciated...
    08-29-2024, 02:05 AM
  • signal.quest
    Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
    by signal.quest
    I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
    I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
    09-30-2024, 11:21 PM
    09-06-2024, 11:40 PM
