Horizontal lines - Westinghouse TX Series TX-42F430S
  • kenzo42
    • Jan 2009
    • 8
    Anyone ever experience this? There are also some vertical lines as well more along the edge. They are fixed lines...almost like burn in.
  • kenzo42
    • Jan 2009
    • 8
    Re: Horizontal lines - Westinghouse TX Series TX-42F430S
    Any thoughts on this?
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Ihandyrepair
      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
      by Ihandyrepair
      Hi guys
      I just started fixing 4k TV few months ago. so I am still learning a lot
      I got this tv from friend complaint is ghosting or horizontal lines on image.
      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
      then it started to show the ghosting white image.
      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
      it has 3 thin small boards at the bottom of the...
      12-05-2022, 04:18 PM
    • ggil44
      Sony XBR-65X750D Horizontal lines bottom of screen
      by ggil44
      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
      05-30-2023, 07:51 PM
    • rstrube
      ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
      by rstrube
      Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
      Hi Everyone,
      I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
      Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
      Yesterday, 01:37 PM
    • rstrube
      by rstrube
      Hi Everyone,
      Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
      Yesterday, 12:19 PM
