Panasonic TX-P42U10E 7 Blinks
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey guys.
    Got this nice looking panasonic tv thats blinking 7 times on startup.
    At the moment im just gathering information so i can work on this tv tonight.
    With removing SC board its blinking 6 times.
    After reading some threads including Shinjo's thread , I found out that most of the time the problem is the SC board or buffer boards. Is this tv one of the models that had "bad screws" ?
    Its a 2010 model.
    SC board = TNFA-4829
    PS = ETX2MM747MF
    Hope that someone can give me some advice what to test first?
    *Pictures tonight , im at work.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TX-P42U10E 7 Blinks
    Originally posted by Moreno83
    Hey guys.
    Its a 2010 model.
    PS = ETX2MM747MF
    No, but like most Panasonic plasmas the SC quits sooner or later. Must be very early 2010, really it should be part of the 2009 model line up.
    what are you like at component level repair? Repaired any SC boards?
    not sure how easy these boards are to get or could be pricey.
    basic first step is to do the SD/SU boards bypass.
    basically remove the 4 Vfg bolts from the SD/SU, disconnect the 3 connectors from sc to buffers.
    short the 2 pins on the sc at SC50, power on and see if it stays on.
    alternatively, check SC2 for short cct or a visual may find FET driver ic burnt or SMD diodes burnt
    or
    remove the SC and start checking the IGBTs for short cct
    Start with Q661,660, 601. if nothing then continue with the rest
    How many hours before you get home?
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Hi TW2005 ,
      Im "good" at repairing/soldering the boards so that wont be a problem. ( removing and replacing components ).
      I just found a similar thread wich you replied to with the same answer so when i get home ill try the bypass on the SC50 connector first.
      Do i only need to remove the screws or remove the buffer boards from the SC board?
      I think i have another pair of these smaller bufferboards. The mainboard looks almost identical to the 3D models that came out in 2011 ( GT20 ).
      Indeed , the panel sticker says late 2009.
      • tw2005
        • Oct 2011
        • 6458
        Hi TW2005 ,
        I don't think any 2010 (Gt20) will help, signals from that along SC20 are different. I just did a 2009 50G15 and was hoping I could use my 2010 V20 to plug in to just for a SC board test with no buffers but can not be done.
        I'll check the schematics but not optimistic, besides i think this will be a SC repair
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          I'll try the test first to see if it stays on or not. I will be home in 6 hours....
          • tw2005
            • Oct 2011
            • 6458
            yeah, I don't think we're going to be online at the same time much
            • tw2005
              • Oct 2011
              • 6458
              Sometimes I think if the SC is suspect, checking for shorted parts is a safer option just in case continually powering the Sc up does more damage. I notice on the 4782 boards there's a diode that shorts and burns long enough to burn the board and track out.
              • tw2005
                • Oct 2011
                • 6458
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Ok , i will remove the board first and check for viscible damage. If the board looks ok , ill do the test.
                  Those fets/diodes , are they on more SC boards? ( same kind )
                  • tw2005
                    • Oct 2011
                    • 6458
                    generally of the same generation so 2009 boards but I used 2010 model parts and got mine running
                    • tw2005
                      • Oct 2011
                      • 6458
                      I have not checked all parts like the large IGBTs which you can clearly see but the small stuff will be correct.
                      R606 10KOHM 0.25W
                      R696 2.2ohm 5W
                      Q661 RJP6065
                      D618 RF101L4S
                      D619 RF101L4S
                      D865 RF101L4S
                      Q441 45G127
                      Q451 45G127
                      D608 MAZ81200ML (12V 150mW) SSMINI2
                      Q401 2PG011
                      Q402 2PG011
                      Q403 2PG011
                      Q501 CPH5524
                      Q502 CPH5524
                      Q521 CPH5524
                      Q522 CPH5524
                      Q421 30G123
                      Q422 30G123
                      Q423 30G123
                      Q601 RJK6026
                      Q660 RJK6026
                      Q701 MMBTA92
                      Q702 2PD601ART
                      Q818 2SK3018
                      IC724 TC7SH14F
                      IC725 TC7SH14F
                      IC771 TC7SH14F
                      IC501 M81707FP
                      IC521 M81707FP
                      PC461 PS9817A-2
                      PC601 PS2701A-1
                      R506 10 OHM 0.25w , ERJT06J100V
                      R507 10 OHM 0.25w , ERJT06J100V
                      R551 10 OHM 0.25w , ERJT06J100V
                      IC464 TC7SH14F
                      IC465 TC7SH14F
                      IC773 TC7SH14F
                      depending on how much surrounding damage is at ic521, these can get taken out whenthat driver shorts out
                      ic561,562 tc74vhct541a
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        Thanks for all the help tw2005!! Will try it when i get home and see if i can fix the problem!
                        • tw2005
                          • Oct 2011
                          • 6458
                          Well if have a load of parts maybe, but lets see what you find first.
                          of course could be buffers but SC is up there.
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            Ok i did what you said.
                            Disconnected the bufferboards from the SC board and used the SC50 jumper.
                            The tv stays on but no picture.
                            This means 1 or 2 buffer boards are bad?
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              Tested both buffer boards and the lower buffer board is short on 2 pins. Rest is all good.
                              Is this the chip thats bad? Or can it be a different part on the print?
                              • tw2005
                                • Oct 2011
                                • 6458
                                Well how ironic. I had a feeling after I'd done all that work it'd be buffer just to prove a point since I was assuming the worst.
                                Are you thinking of trying to replace just the buffer IC? have you done that before? watch out for the sealant as that is also under that chip makes it hard to get off but I had a go at removing these for fun and I found using acetone helped with removing the sealant making it separate a bit easier.
                                Not sure what you're asking whther to confirm it's the SD or you want to narrow it down to the IC. you'd have to show us the pins shorted but you should be able to trace the tracks to what IC
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  Haha , i was suspecting the SC board also!!
                                  Its the lower buffer board. the chip is located on the bottom of the board. ( connector 3 from the left ).
                                  Only 2 pins are short , the first and almost the last 1.
                                  Not sure if i want to repair it , would need a chip first! Cant take 1 from a other SU boar d right?
                                  Costs of 1 board is just 20$ …..
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Get the board, keep the dead one for another day. I've been praticing on a damaged 5090 board, just getting good at it. I use generous mounts of acetone and pick away at the silicone. get a a sharp fine blade and cut the legs against the casing, don't go too deep there's tracks below. then more acetone and grab the ic twisting back and forth.
                                    should just pop off. then get the rest of that goo off , using something like a toot pick to work it, carefully desolder the remaining legs.
                                    I already posted these on ricosavy thread as these buffer boards are starting to run out.
                                    The chips are not cheap maybe $4-7 each for me. adds up fast if all 6 - 8 are blown on a board and not having the correct gear or experience.
                                    1 or 2 chips I'd have a go at.
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      Thx for the update! This looks like a AS15 chip wich i have replaced many times.
                                      I tried to turn the tv on without the ribbon cable for that defective chip but still 7 blinks.....
                                      Think that the tv only works with all chips intact...right?
                                      Question is , do i need the EXACT same chip? Or can i use a different one? Got many SU boards.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        The fault is on the board , not the panel so no that won't work. can you use different chips? maybe.Tom seems to think there's some interchange, maybe another chip for FHD panel and a panasonic, I don't know. Not my thing.
                                        I'd expect buffers from any 2009 FHD will have the same chip.
                                        I guess AS15 has 4 sides, but 48 pins , TQFP-48 9 x 9 mm, compared to 128 pin?
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • riparo
                                          Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
                                          by riparo
                                          Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
                                          I attach a link to download the service manual, thank you for anyone who can help me
                                          https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
                                          01-11-2024, 12:35 PM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
