Sylvania Plasma TV
  • Ferhere
    • Apr 2015
    Sylvania Plasma TV
    I have a Sylvania Model 6842THGA Plasma tv that has alot of sparkles. the picture looks like alot of noise and fades in and out. I checked the voltage on VS and VA and found them both higher that stated on the sticker. I tried to adjust these but was unable to adjust them down any further to get the voltage correct.
    Any other suggestions?
    The inside of the TV is LG
  • Lintesir
    Panasonic P42S30 Plasma - Pink sparkles
    by Lintesir
    My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
    There is about a 5cm high region at the top without any sparkles,...
    07-26-2024, 03:16 AM
  • Nirrain
    Panasonic TX-P42S20E Plasma tv. First purple sparkles, now completely black
    by Nirrain
    I have a Panasonic TX-P42S20E plasma TV that lately has been showing flashing pink pixels when the picture is bright (similar to picture 5 in this post), primarily on the top half but to a lesser degree in the buttom half.
    I've tried to change VSUS to high but it made the issue even worse so changed it back.
    However, this is all a backstory as yesterday after being on for about 5 minutes the screen turned black. I've tried to hard reset (hold power on tv for 30 sec).
    When turned on the green LED flashes 6 times and then stays on continously....
    07-09-2021, 02:38 AM
  • DerD
    Panasonic Plasma TX-P50Gt30E with sparkles, brightness problem
    by DerD
    I have build up again a defective SC-board TNPA5335 with all! IGBTs and several drivers and other components, after incomplete 6 blink repair and further issues. Finally I got the board almost to work again, running now at least for some minutes without shorting down.
    Anyway, something is still wrong, I guess but not 100% sure that it is on the SC-board.
    Latest step before now was sparkling all over the screen, then Q16820 was replaced and situation now is this. Also to say that Q661, IC921 and other parts for Vad have been replaced too, not only Q401-3...
    05-04-2021, 10:39 AM
  • Mcfeetroy
    homemade speakers AN5277 How to adjust the volume?
    by Mcfeetroy
    Hello everyone. I soldered the speakers according to the circuit diagram on the AN5277 sound amplifier microcircuit. Everything works fine (I only added a ferrite ring to remove the sound transmission interference)
    But I can't adjust the sound (there is no variable resistor or something similar for this in the circuit....Please tell me how I can adjust the sound? What needs to be added to the circuit?
    10-27-2024, 10:19 AM
  • ArMaaN376
    Samsung PS51E550 Plasma TV
    by ArMaaN376
    I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
    Opened TV cover & observed foll
    a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
    b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
    c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
    How to confirm Y -Buffer board...
    06-19-2024, 04:05 AM
