Toshiba 42HP95 Plasma TV
  • clarkejr
    • Mar 2015
    • 5
    I need help disconnecting the Sein board from the signal board. I took apart a lap top and destroyed the display connector without trying so now I am afraid to mess around with these two Toshiba connectors. I have included two photos. There is a spring type connector at the top and a square black connector below it that I have to remove. Can anybody tell me how to safely remove both of them?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Toshiba 42HP95 Plasma TV
    The right hand side --with the tabs on lifts vertically upwards....
    TELEFIX
    • clarkejr
      • Mar 2015
      • 5
      That worked fine. Thank you.
      • michhak
        Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
        by michhak
        Hi guys,
        i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
        It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
        11-17-2021, 05:45 AM
        09-06-2024, 05:59 AM
      • Tomylee
        No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
        by Tomylee
        Sorry for the person who’s going to read all this !
        I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
        While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
        During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
        07-11-2025, 11:52 AM
