LG 42LH40 - No Power
  • Nerfinator
    • Feb 2015
    • 56
    I have an LG 42LH40 that no longer powers on, owner reported a loud pop and it shut down. I believe the schottky diode blew out on it but I'm new at TV repair and I'm curious that if I replace the component will that fix the TV or is there a good possibility of another component being the cause for the diode to fail. Below is a picture of the diode, still on board. All the caps look good, however their is a ceramic disc cap by the fuse, it has a plastic coating on it that is all sticky so I'm thinking of removing to test the cap, not that it's goo that leaked from the cap.
    Also, I've never replaced a diode before, it looks like there is thermal paste behind the other two next to it and just a grey mat behind the one that failed. Should I reuse the mat or use some Arctic 5 thermal paste behind the new diode?
    Any input would be wonderful, thank you.
    Photos ==> https://onedrive.live.com/redir?resi...t=folder%2cjpg
  • Nerfinator
    • Feb 2015
    • 56
    Re: LG 42LH40 - No Power
    If it helps any, the fuse by the power input is also popped.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
      03-31-2024, 02:12 PM
      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
      I was working on this CNC machine today found no keyboard functioning no control relay powering on
      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
      Found shorted diodes on main controller relays there are 3 of them that...
      01-07-2023, 05:43 PM
      09-06-2024, 05:59 AM
