TNPA4657 failure (TH-42PZ85B) w/ 120 ohms between VSUS and GND
    Odd failure here.. TH-42PZ85B with a 2 blink code indicating low or short Vsus. When SC was removed, code changed to 7. Tested SC and found it has no direct short but 120 ohms between Vsus and GND.
    Loads of IGBTs dead but the odd thing is, the Vsus isn't dead short, so I'm lost as to how this has happened - suspect the short is hiding behind some component, but not sure what exactly.
    Anyone else seen this? Will just order a new board at £15
  • tw2005
    • Oct 2011
    • 6458
    Re: TNPA4657 failure (TH-42PZ85B) w/ 120 ohms between VSUS and GND
    120ohms would be good enough to be classified as dead short on Vsus. Normally resistance there on the 2010 boards is 300K - 3meg.
    I know every now and then a board is not dead short at SC2 for the 5081 boards, and throws a 10 blink instead of 4.
      Yep agreed it's short just weird it's not dead short. It looks like the SUS UP path died, has about 0.1 ohm C-E then the VAD pass FET popped about 100 ohm drain-source. SUS-DN looks like it survived, kinda odd. Not too worried, will use this as a spare parts board. The board is pretty cheap as it rarely fails on the PZ80s. This has to be my first one after something like 12 P board and 1 A board fault.
      • tw2005
        • Oct 2011
        • 6458
        I think if the MC201/301 module issue did not exist, these would have to be the pick for reliability so long as power consumption was not a consideration.
        I double read the post just to convince myself I was reading SC failure, pretty rare.
          I think most Panny plasmas are pretty reliable all considered, they just have consistent issues (such as the loose screw issue.) On the modern panels (2011 onwards) they actually look pretty easy to repair, you'd only have to replace IGBTs & gate drivers... maybe a buffer IC in the worst case...
          Certainly, considering some of what Samsung & LG were putting out at the time, Panny plasmas are excellent.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            I have seen high ohm shorts on new production board caused by dust on the image used to made the board. If one did not properly get rid of short then I have seen them grow back together. We use to use a large capacitor and charge it up and then apply it to board. The problem with that is they can grow back together. We found using a Fluke meter in the Ohm scale one could hold one probe stationary and move the other probe to find the lowest resistance. Once we found the lowest resistance we moved the stationary probe over to this area to find a more specific lower reading. We could narrow down to a few inches and then use a X-acto knife to cut between the runs and then use lacquer fingernail polish to coat the cut. Of course with multi-layer boards I guess one would throw it away.
              Can confirm SC board fixed the fault.
              • npielawski
                MacBook Pro late 2016 (820-00239) with multiple failure modes.
                by npielawski
                I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                10-15-2025, 01:53 AM
              • narf
                Epson EB-U42 projector / Caps with 0.7 ohms ?!
                by narf
                hi all,
                first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                what i've found so far:
                - the PSU does its job and supplies 12V to the mainboard via the connector.
                - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                - not far away, there's the first cap with a resistance of 0.7 ohms....
                07-02-2024, 03:53 PM
              • puccovelli
                Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
                by puccovelli
                Hi all, I hope this is the right place to post.
                I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
                I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
                1] Could someone confirm what the component that has blow actually is (and where I could get another from).
                2] Whether this component is likely to cause the RAM failure issue, and if replacing...
                10-11-2025, 06:30 AM
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                Replaced emmc.
                Terminal log
                UART
                AC_ON
                E-B
                FDE enabled
                06-01-2025, 02:11 AM
              • ctroxtell
                Carrier HK50AA063 display controller common failure help
                by ctroxtell
                I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                02-05-2025, 05:31 PM
