Hello Everybody
I have this PS43D450 Samsung Plasma with a strange problem which I haven't found a solution or even some mention of such a problem on the forums/internet.
This TV when powered up, starts arcing (under the X-Electrodes or X-Flex cables) with loud popping sound and there does not appear any picture or even glow on the screen. It just keeps arcing. The Arc travels from panel glass to the back metal chasis, under the X-electrodes.
I disconnected all X and Y electrodes (flat brown cables) and turned on the TV. In this state, I have observed the following.
1) Green LED on control board blinks every 1 second (which seems normal)
2) VS, VA, VSC and VE are all normal (as per panel sticker)
3) Then I turned the TV off and connected X-Electrodes and only one (top) Y-Electrode and then ran the test pattern.
4) Test pattern started on upper portion but many pixels were not coming ON. After few minutes of running the test pattern, many pixels started turning on.
5) If I attach more Y-Electrodes, the arcing starts under the X-Electrodes. With only one Y Electrode, there is no arcing except when you power up the set and before the start of test pattern.
What could be the possible reason ? I haven't seen this kind of problem before nor anybody else mentioned this kind of issue with a plasma TV.
Help and guidance will be highly appreciated.
