Samsung LN46B500P3F
  • _N_
    • Nov 2010
    • 52
    Re: Samsung LN46B500P3F
      No PFC IC with that P/N that I can find.
      • _N_
        • Nov 2010
        • 52
          Originally posted by _N_
          7 pins all read 5.16 Vdc
          the 8th back pin reads 12.6 Vdc
          What did you use for GND pin, the chassis or the negative leg of the main filter cap?
          • _N_
            • Nov 2010
            • 52
            I apologize you were correct. measuring now.
            • _N_
              • Nov 2010
              • 52
              #26
              pins 1-4 measures 75.8 vots
              8 pin measures 65.2 volts
              measured to chassis ground.
                OK, the readings are wrong because you are working in the primary side circuit, the GND ref for the meter will be the negative leg of the main filter cap not the chassis GND (CHASSIS GND can be used for GND ref for the cold secondary side of the power supply).
                The GND pin of the PFC IC is also connected to the Negative leg of the main filter cap but i would suggest you to use the negative leg of the cap instead in case the probes slip on you.
                • _N_
                  • Nov 2010
                  • 52
                  #28
                  Measuring from the main 2 filter caps laying on there sides there NEGATIVE lead to the 8 pins on the pfc With the TV on.
                  gives
                  1: 0.97V --- 8: 14.6
                  2: 0 --- 7: 0
                  3: 0 --- 6: 0
                  4: 0 --- 5: 0
                    OK, 14.6VDC on VCC pin is good (minimum Vstart is 12VDC but no action on the Gate drive pin at all.
                    We need to check more parts in the PFC section:
                    Diode DP804, 805, 806
                    Resistors RP801
                    I believe you already check the fuse FM801S?
                    • _N_
                      • Nov 2010
                      • 52
                      #30
                      Resistors RP801
                      Diode:
                      DP804: in diode check sends voltage 1 way ,running 150V through it
                      DP805: in diode check sends voltage 1 way ,running 150V through it
                      DP806: in diode check sends voltage 1 way ,running 150V through it
                      Resistors:
                      RP801: 50
                      fuse FM801S: checks good not blown up
                        Do you mean it shows 0.150V on the meter in Diode, not 150V?
                        But any way, I am looking for shorted out Diodes, but they are OK.
                        I would try new IC at this points since it will take me lots of times to trace out the circuits.
                        • _N_
                          • Nov 2010
                          • 52
                          #32
                          Its not the diodes.
                          I pulled them out about a week ago and tested them out of circuit.
                          along with all fuses, and resistors I checked there color codes to see if they were in spec ;}The through hole stuff.
                          Its the simplest thing to check with a meter. I have one of those little ebay component checker things with a LCD.
                          Its the ICs that drive me nuts not to mention the teeny tiny laser etching on them.
                          But im learning ones never to old, to keep at it.
                          Besides its not all lost, others will read your posts and my electrocution an learn how to test a psu.
                          Next? at your leisure of coarse.
                            Lets try resistance test on the IC, Check the resistance of all the pins against GND pin to see if the readings will give us a clue.
                            • _N_
                              • Nov 2010
                              • 52
                              #34
                              will do, tomorrow first thing. :}
                              its 1 AM here.
                              • _N_
                                • Nov 2010
                                • 52
                                #35
                                Bud I went back and added a little solder to the fets and I got an interesting affect now, similar to what you wrote in another posting.
                                Now, when I turn it on the back lights turn on for a second and turn off and recycle repeatedly with the PSU the relay can be heard clicking in conjunction with the lights.
                                So I pulled everything off AGAIN and measured and Again everything appears not to be blown, Nothing seems shorted. No bubbles on the chips
                                no tiny burnt holes. Could the components be breaking down when in use becoming "leaky"?
                                I then Pulled off the motherboard cables and plugged her into the Ac outlet and the lights "come on" woohooo:} for a brief second then stay off ahhhh dammit :{ .
                                I got the idea from this posting you made:
                                " : BN44-00265A schematic needed:
                                It is strange that the backlights will flash 4~5 times in sync with cycling on and Were those two MOSFETs failed as shorted?
                                BTW, the PS_ON and the Inverter ON/OFF pins have pull-up resistors, so if you disconnect the cable between the power supply/inverter board board, the back lights should come on the minute you plug the TV into the AC outlet."
                                  Right now the main thing is that when you power on the power supply board by itself, the relay should stay on since the board has built-in pull up resistor for the PS-ON pin, so then the PFC Voltage should be >360VDC, that is what we need to get it going first.
                                  • _N_
                                    • Nov 2010
                                    • 52
                                    #37
                                    Bud Id like to thank you, For all your help.
                                    It was and is genuinely appreciated.
                                    I ended up selling the 46' tv for its lcd panel to a local Tv repair shop ( joys of Craigslist ,wasn't even looking and they had an add. For a "Sammy 46 lcd wanted" $120.00. sweeet)
                                    I didn't need it, Ive got a spiffy samy super thin on the wall.
                                    !! BUT before I left I saw a pro-scan plded3996a-c2 on the floor they let me have freee.
                                    Annoying questions will be coming with pics!
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:20 PM
