Panasonic Plasma (TH-50PZ77U), bad panel or bad buffer card?
  • Computer_Eng
    • Oct 2014
    • 16
    The set is a Panasonic Plasma (TH-50PZ77U). I was troubleshooting the set in an earlier thread when it spontaneously started working. It's failed again and I'm trying to decide if it has a bad panel or a bad lower buffer card (SD card).
    If I remove the lower buffer, the set works fine (although with only the top half of the picture). With the lower buffer in place, the set shuts down with an SOS7 code (7 blink code). I checked the lower buffer with an ohmmeter and I can't see any shorts on the board (ground to VDD, VDDH or to the output pins).
    Another symptom is if the lower buffer card is installed, but the 5 panel cables going to the lower buffer are unplugged, the set does not go into shutdown and works with the top half of the picture. If any one of the 5 panel cables are plugged in, the set shuts down. It doesn't matter which one is plugged in.
    This confuses me as I could imagine a short in the panel causing this kind of problem, but then I would expect the problem to be isolated to one specific panel connector and not any one of the five connectors. The “any one of the five” seems more like a problem that shows up when the panel drivers on the lower buffer card are active and switching screen voltages. However, the fact that earlier the problem seemed to come and go made me think it was a bad panel. Also, I've tried a couple of different lower buffer cards, but no luck. So either I've got three bad lower buffer cards or a bad panel.
    Could a bad panel explain all the symptoms? When a plasma panel fails spontaneously and without the screen being cracked, what actually goes wrong electrically?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Panasonic Plasma (TH-50PZ77U), bad panel or bad buffer card?
    Bottom buffer faulty.
    TELEFIX
    • Computer_Eng
      • Oct 2014
      • 16
      I'm stuck on troubleshooting this Panasonic Plasma. I ordered and installed a third lower buffer (SD Card), but no luck. I'm still getting a 7-blink shutdown (SOS7). At this point I'm pretty convinced it's not the lower buffer. The problem was originally intermittent, but now it consistently shuts down within a few seconds of turning it on.
      The Y-sustain (SC card) and the upper buffer (SU) appear good as the top half of the picture works perfectly when the lower buffer is not installed. If I remove the upper buffer, the set will still shut down if the lower buffer is in place.
      I hypothesize the lower buffer is good because I've tried multiple cards from two different suppliers with the same results. When the problem was intermittent, it occurred on at least two different lower buffer cards. I haven't found an obvious short on any of the lower buffers. However, the fact that the shutdown only occurs when the lower buffer is in place points to an interaction with that board. If I power up with the lower buffer installed, there is time to see that the top half of the picture (upper buffer region) is corrupted before it shuts down.
      There has been no physical damage to the panel, so if it has a problem, then it just failed over time. Also, as I mentioned earlier in the original post, the problem will occur if I plug in any one of five lower panel connectors. If there was a panel issue, I don't see how it would show up simultaneously on all five lower panel connectors.
      Any ideas on what I could try to further isolate the problem?
      • tw2005
        • Oct 2011
        • 6458
        run it with the upper and get all panel voltages as listed in the manual.
        then do the same with just the SD installed and list them
        • Computer_Eng
          • Oct 2014
          • 16
          Thanks for responding to my post.
          I'll check the voltages requested. I plan to check Vsus, Ve, Vset, Vad, Vscn and Vda. Let me know if there any others that would be useful.
          One problem I foresee is checking voltages with the SD (lower buffer) card in place. If I fully connect the SD card, the set will go into shutdown and most or perhaps all of the voltages will go to zero. Typically, the set will shut down before I can obtain meaningful readings. Any suggestions?
          • tw2005
            • Oct 2011
            • 6458
            I’ll check the voltages requested. I plan to check Vsus, Ve, Vset, Vad, Vscn and Vda. Let me know if there any others that would be useful.
            have the probes on them as you turn on and observe what they get to.
            I'm just wondering if there's a voltage near a trip point. It's the Sc that monitors and trips 7 blink. I've had a bad SC in a 2009 HD model trip 7 blink, no shorts but I think from memory it may have been a bad vad gen cct as it was right on the lower end or just below. The vad gen cct must have been defective because on that one the trimpot made no difference to the voltage. Ocassionally I could get it to stay on if i repeatedly turned it on and off. The picture was ok but a little flicker.
            Just thinking looking elsewhere for clues on this one.
            • tw2005
              • Oct 2011
              • 6458
              not sure if any of this helps, is the 42" maybe similar problems?
              https://www.badcaps.net/forum/showthread.php?t=21700
              https://www.badcaps.net/forum/showthread.php?t=24894
              https://www.badcaps.net/forum/attach...1&d=1355692078
              • Computer_Eng
                • Oct 2014
                • 16
                I checked the voltages on the set and for the most part, they seemed good. These were the values without the SD card.
                Vsus = 183.8 (184 nominal)
                Ve = 160.8 (161 nominal)
                Vset = 239.8
                Vad = -90.2
                Vscn = 49.38
                Vda = 74.8
                I pulled out the SU and installed the SD and checked the voltages again. All of them seemed to be within a few tenths of the prior readings before the set went go into shutdown.
                I will attempt to measure the +5V which supplies the VDD on the SU/SD board PDP chips if I can locate a reasonable test point. This voltage is sourced from the floating section of the SC board.
                The part of the SC board which sources TPSC1 also appears important for the SU/SD cards as that feeds VDDH on the PDP chips and is also monitored by the SC.
                Thanks for the pointers to the prior threads. I'll read through them and see if they can provide some inspiration.
                • tw2005
                  • Oct 2011
                  • 6458
                  Vset = 239.8
                  Vad = -90.2
                  Vscn = 49.38
                  Vda = 74.8
                  yeah, so as you say these are all in tolerance and if they are the same with the SD I'd look at the 5v for the buffers and also the 16V. i was trying to study the 42" version and in that these also form part of the sos7.
                  I'm seeing two Vfo sos detect ccts and 5v(sc1) and 5v(sc3) marked Vf+5v at the buffer end as part of the 7 blink shutdown cct as well which are buffer board related
                  • Computer_Eng
                    • Oct 2014
                    • 16
                    Good and bad news on troubleshooting my Panasonic Plasma.
                    Good news is the set is now working. Bad news is that I didn't really do anything to fix it.
                    This is actually part of the pattern. The set will suddenly stop working then it will spontaneously revive itself. This has happened a couple of times now. These "outages" can last for weeks.
                    I'm going to try and get measurements on the SOS7 circuitry while things are working so I'll have reference points when it fails again. I don't see how I can have any blown high power elements or bad driver chips. Maybe a bad solder joint or a marginal capacitor?
                    Thanks for the reference to the 5V and 16V supplies. The 50" and 42" must be pretty similar as I found the identical elements on my 50". One last anomaly I noticed was in the ground on the floating voltage section of the SC board. With the set working, I measured the difference between the SC floating ground and the chassis ground (greater than 10 volts). From time to time, the voltage difference between the two grounds would change and I would hear a faint noise from the "P Board" where Vsus originates. I'm going to try and figure out which components are making the noise. Could be nothing. Maybe the voltage difference changes when the screen displays a brighter or darker image.
                    • howardc64
                      LG 49UJ6500 LCD panel lighter band that goes away
                      by howardc64
                      49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                      Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                      02-19-2023, 12:13 AM
                    • triplefour
                      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                      by triplefour
                      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                      tcon is built into mainboard.
                      Only one cable goes to panel boards.
                      there is a cable from one panel board to the other that links them.
                      cost cutting measure that results in us having harder time to diagnose.
                      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                      07-28-2022, 07:59 PM
                    • Storyteller12
                      QN55Q60R Service Menu Panel Help
                      by Storyteller12
                      I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                      I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                      I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                      the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                      01-13-2024, 01:57 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • maneatingmonkey
                      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                      by maneatingmonkey
                      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                      03-27-2024, 07:17 AM
