Dp46841
  • KevinCro
    • May 2014
    • 104
    Dp46841
    Hello All I have a Sanyo DP46841 that I replaced both the digital and analog mainboards. The tv will now power on but I have to hold down the power button longer than seems normal. There is no standby light on the front when I plug the tv in. However, I get 4.95 volts at the 5V pin on the PSU output to the mainboard. Is there something wrong with the standby circuit? Any help is appreciated. I have posted a link to the psu board from shop jimmy. I use that because its easier to zoom in and look around on the board. Not spamming. Thanks.
    http://www.shopjimmy.com/sanyo-1lg4b...upply-unit.htm
  • MagicSmoke
    • Feb 2011
    • 275
    Re: Dp46841
    The LED on my Sanyo DP50747 plasma does not light when off, turns green when turned on.
    • KevinCro
      • May 2014
      • 104
      Re: Dp46841
      Okay great. Thanks for the response. I just wanted to make sure I had all the kinks ironed out before I put it all back together. Just to give this thread some usefulness, this tv had been a victim of a lightning strike. When I got it, it wouldn't do anything. I checked the 5v standby voltage from the PSU and got 4.95 volts so I suspected the main board. I replaced both the analog and the digital main boards and the problem was corrected.
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • fharris1977
        Vizio D50u-D1 Dead Set No Standby
        by fharris1977
        Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
        12-28-2023, 10:25 AM
      • Crystaleyes
        Samsung BN44-00259A standby question
        by Crystaleyes
        Hi all.
        I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
        SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
        Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
        The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
        08-11-2023, 05:15 AM
      • psssst
        Yamaha TSX 120 Standby Problem
        by psssst
        Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
        03-01-2024, 07:25 AM
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
