Samsung LNS4051DX
    Re: Samsung LNS4051DX
    So when the P-ON is present, every functions are OK, the pictures and sounds are good.
    What you can do for now is to use a switch to feed force on to the POWER -ON/OFF pin with a switch so at least you can use the TV until it breaks down completely.
    • Rmasters3
      • Mar 2010
      • 126
      I finally located a used--supposedly from a set with a damaged display--main board. I get audio, and occasionally video that sometimes lasts for an hour or more. Then black screen. I have replaced the usual suspect caps in the power supply. I am guessing the next step is to recheck the connector voltages. Is audio-no-video commonly a power supply issue?
      • Rmasters3
        • Mar 2010
        • 126
        Just checked the voltages at the white connectors--both the long and short on the upper right side of the power supply--all check out correctly on the longer one.
        Short one at top On/Off 5.4V, A-Dim 2.4V, P-Dim 4.98V, E-Sym 5.3.
        4 blinks when turned on, Video occasionally works when I turn it on--then goes black after a few minutes. Audio works, no problems.
          "Short one at top On/Off 5.4V, A-Dim 2.4V, P-Dim 4.98V, E-Sym 5.3. " So those readings stay the same when it works and when it does not work?
          • Rmasters3
            • Mar 2010
            • 126
            These were the values when the set had audio but the screen had gone black (backlights no longer on). I did not test voltages when set was working correctly
            I turned set on, it worked for a few minutes before screen went black and backlights off but audio remained.
              'E-Sym 5.3' this may be the one that will give me the clue, so when it is working we need to know what is Voltage is.
              • Rmasters3
                • Mar 2010
                • 126
                #27
                Tested the 'E-Sym while set was playing a DVD on HDMI2 and got a consistent 5.35-5.37VDC. I used 3 different digital meters, FWIW.
                  OK, the old main board was having the PS-ON problem not present and we were able to force on using the resistor. This replacement main board is in place and now you are getting black screen after an hour or so. I would put the old board back in and use the force on to see if it still goes out (backlights) after an hour. You were getting pictures and sound OK when forced on, right? (see post 21)
                  • Rmasters3
                    • Mar 2010
                    • 126
                    #29
                    I didn't do the force on with the old board. New board is still doing the same. Contacted the new main board seller who said the problems is in the inverter board, which I now have on order.
                    • Rmasters3
                      • Mar 2010
                      • 126
                      #30
                      FWIW: I ordered and installed an inverter board (left side when viewed from rear of set), but still got the erratic shut down to black screen Found another thread indicating the power supply transformers solder joints were sometimes problematic, so I touched up those--none looked questionable, but did it regardless. Also again, swapped out the used 22uf@450 V cap on the PS. I had two 22uf@450V, used caps and tried the second. Set has been working--latest run nearly 12 hours with no issues.
                        09-07-2024, 05:50 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
                        Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 06:20 PM
