Samsung plasma PS42Q91HDX/XSA turns itself off/on.
  • Dakkrew
    • Feb 2015
    • 8
    Hey everyone, PS42Q91HDX/XSA Samsung plasma issue here. TV wouldn't turn on so replaced 2 (visually) bad caps on the PCB. TV then fired up straight away and all settings OK. 10 minutes later the set turned itself off and began clicking on/off but not actually turning on (just like a bad cap problem). If I turn it off at the mains for a while, then try it, it's fine again for a short period.
    Should I replace the rest of the caps on the PCB? Are there other issues with this model I should know about?
    Thanks in advance for your help and advice.
  • tw2005
    • Oct 2011
    • 6458
    Re: Samsung plasma PS42Q91HDX/XSA turns itself off/on.
    reflow all the heatsinked fets etc especially the centre heatsink as these also have a habit of cracked solders. If you keep trying to run it like this those FETs and a whole bunch of smd stuff underside will blow if it does have bad joints.
    • freakaftr8
      • Oct 2012
      • 3743
      Look at the power supply for bad solder connections. Mostly the mosfets and components attached to the heat syncs. They are probe for fatigue. I would try to resolder any suspicious connections on the bottom of the board.
      • freakaftr8
        • Oct 2012
        • 3743
        Lol tw2005 beat me to it.
        • Dakkrew
          • Feb 2015
          • 8
          Thanks guys. I'll let you know how it goes.
          • Dakkrew
            • Feb 2015
            • 8
            Hey Guys, you were spot on! Didn't see it when I first checked the board over but on closer inspection, as you both said, the centre heatsync joints were cracked. Reflowed all heatsync and fet joints and the telly works like a bought one!
            Thanks very much you guys rock!
              09-07-2024, 05:50 AM
            • Egidio85
              Samsung UE55F8000SZ Turns on and off immediately
              by Egidio85
              good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
              This defect happens continuously, hearing the classic click of the relay every time.
              Power supply board BN44-00636B
              disconnecting the mains and lamps from the power board always causes the same problem.
              Is it normal that without anything connected this power supply turns on and off cyclically?
              any suggestions on what to check?
              thanks in advance
              03-11-2025, 12:45 PM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
