Samsung HL56A650 DLP Chip - Worth Replacing?
  • dmanthei
    • Feb 2015
    • 17
    I picked up a Samsung HL56A650 DLP TV for free off Craigslist today.
    The seller said it looked "snowy".
    Brought it home and, sure enough, there are stuck white pixels all over,
    but it otherwise looks like it works fine
    (I was able to play Netflix through it no problem).
    Doing a bit of research, it looks like the DLP chip is bad.
    The downside is that the DLP chip is like $180+ USD. Ouch.
    So, as this is a TV from 2008, but is 1080p and seems decent,
    do y'all think it would be worthwhile to invest $200-ish into fixing it?
    One thing that puts me off it a little bit
    is that DLP has that aspect that makes it flash a rainbow of color
    if you dart your eyes quickly left and right.
  • Ltank
    • Jun 2013
    • 776
    Re: Samsung HL56A650 DLP Chip - Worth Replacing?
    I would not bother. Even if you replace the DLP chip ok, all the other boards generally are not available except maybe a power supply.
    • nomoresonys
      • 12081
      • U.S.
      yep, its crazy, only 7 years old but already a dinosaur.
      • Michale32086
        • Nov 2011
        • 1453
        It's been my experience that DLPs are like Fixer-Upper Houses...
        A money pit that just needs a "few dollars more" to be "done"..
        Just my 2 cents...
        • nomoresonys
          • 12081
          • U.S.
          they sell some of those parts for what seems like too much money on ebay, don't know if theyr selling them or not tho.
          • Michale32086
            • Nov 2011
            • 1453
            I just looked on Ebay after getting a nice DLP in.. $180 is about the cheapest going rate I have seen..
            I kick myself as I have probably thrown out a half dozen DLPs this month. I always scavenge the lamps. Never thought to scavenge the DLP chip..
            • dmanthei
              • Feb 2015
              • 17
              Do you guys think there's any value in it,
              or should I just put it back up to give away?
              I'd love to sell it for $30-$40
              to recoup the loss from the plasma TV that I was misled on.
              • nomoresonys
                • 12081
                • U.S.
                could sell color wheel, dmd board, power supply, etc., a bit of a hassle, but you might could get over a hundred without much trouble, ebay has a vast audience.
                  09-07-2024, 05:50 AM
                  Common SPI bios chip programming Questions and Answers
                  by SMDFlea
                  Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                  A: If you can`t read from it how do you expect to write to it ?.
                  Q: Why is my bios chip unreadable ?.
                  A: The programmer is faulty or has a worn or broken zif socket.
                  The USB cable is frayed,connector pins worn or some other physical damage.
                  Not enough amperage or voltage to power the programmer properly.
                  Bad...
                  09-02-2021, 04:40 PM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
