Re: TNPA5349 Buffer replacement
I have now started to go round checking on the pads were the legs have been lifted on the diodes + IGBTs to see if any show shorted there was a small Fet Q600 that I had missed but there is no short on that. I will also pull the 2 cap from across SN2 socket as well do you think that I am right about the test across the diodes by the buffers as these show short?
I have heard that the buffer ICs can go on this set; I've documented a possible cause elsewhere on this forum, but I can't see how when you isolate all the parts you have, you still get a short across SN. You have essentially removed the only path to the buffer ICs by disconnecting all those transistors so something else must still be wrong, somewhere... I don't know where...Leave a comment:
are you sure all the legs are free and not a solder dag still touching the board?Leave a comment:
Tom GTV sell the chip on eBay and in there add they say top buffer is the normal one to go (heat)and goes s/c, and tested should read 800ohm one way and o/s the other ? bad buffer will read s/c.i can only think they mean to read across the diodes by the side of the IC? if you look I have cut and re joined the resistor not that on my meter reads 2.37 ohmLeave a comment:
So you've isolated every transistor and still getting 13 ohms?
Try isolating the big white 2.2ohm 5W resistor, from memory that's the Vscan source for the buffer ICs, would eliminate a potential short from there.
I've never seen this before, really odd, perhaps a small little diode is shorted somewhere.Leave a comment:
with all legs lifted on diodes + IGBT from board the SN2 shows 13.9 ohms across the socket, I only get buzz from meter when set to continuity? shows nothing in diode or 200ohms mode between tab and ground and only on this buffer IC. but have had this before ,the last time when the buffer was removed so was the shortLeave a comment:
You would need to test to floating ground. Can you get a photo of the SN board?
Due to the internal parasitic diode structures, shorts to actual (cold-earth) ground aren't necessarily bad...
If they are bad, it indicates something else on the SN side is still short, besides the IC.
The ICs themselves have -no- direct electrical connection to ground, they are floating -190V (-Vad) below ground and the outputs can switch between -Vad and up to -Vad + Vscan in normal operation.
So that in itself, indicates that -Vad or Vscan is shorted somewhere to ground (not the buffer IC)Last edited by tom66; 02-11-2015, 05:14 AM.Leave a comment:
the IC is showing shorts to ground that is how I found it , if I run my meter in continuity over the tab sockets and board ground this one rings out and after removing the silicon from it most pins are short to ground? all other tabs are clearLeave a comment:
Hi Tom if you read through you will see that Q661+Q662 are shorted but that is all apart from the buffer IC, I had lifted the legs on all 17 devices on the board and SN2 was still showing short, that lead me to the buffer IC4803 short, my Question to TW was did he think the set would power on with one missing buffer and Q661/662 replaced? FlockoLeave a comment:
You still wouldn't get short on SN2 if buffer ICs were bad... something else is shorted. The ICs can't short to ground, only to their own floating ground, which would only cause Vscan/-Vad to drop out (causing a 7 blink SOS)
The set may work with a missing IC but any other ICs that chain data off of it will be blank. So if it's the top most or bottom most IC it might not work. If it's in the middle it might work.Leave a comment:
Thanks TW yes that goes a long way, well I have a chip on the way from sparedparts.com £10 and I have my digital microscope, I have changed 20-30 gamma chips and all the SMD bits on these SN/SC/SS boards with no problems so I will give it a go, as long as I can get the old one off clean, I am going to change the shorted Q661 and Q662 , and with the buffer chip removed run the board in the set, I think it should power up with the one buffer chip missing ?. I have news on that other 37"Panasonic set with the TNPA5063 SC board in that is all fixed and working, I will post details on here when I have more time on my hands. soon be the start of the F1 year, I don't think I can make it over to you for the first race, but my money will still be on Mr Button to do it again this year. Flocko
With those panasonic buffers, those Ics have that grey sealant which also has heatsinking properties under the chip and it sticks very,very well. i tried and failed on a bad board, I think the trick is to completely remove every trace of it from the pins, maybe carefully cut the legs hard against the ic.
desolder the pins, then grip and twist that ic free.
but I failed so better advice may be out there on this. not sure how many have tried yet on a panasonic board
do you think replacing those fets ar it or maybe the usual smd stuff like drivers and transistors as well?Leave a comment:
A short on the SN power connector would not be caused by a bad buffer IC. It is still possible the IC is bad, but there are also probably other faults you need to check for first.Leave a comment:
Thanks TW yes that goes a long way, well I have a chip on the way from sparedparts.com £10 and I have my digital microscope, I have changed 20-30 gamma chips and all the SMD bits on these SN/SC/SS boards with no problems so I will give it a go, as long as I can get the old one off clean, I am going to change the shorted Q661 and Q662 , and with the buffer chip removed run the board in the set, I think it should power up with the one buffer chip missing ?. I have news on that other 37"Panasonic set with the TNPA5063 SC board in that is all fixed and working, I will post details on here when I have more time on my hands. soon be the start of the F1 year, I don't think I can make it over to you for the first race, but my money will still be on Mr Button to do it again this year. FlockoLeave a comment:
Does sympathy count as help? You have my sympathyLeave a comment:
I have a Panasonic TX-P42S30B that has shorted SN board TNPA5349 fitted. And was hoping for the normally shorted Q401/Q402/ect fault But after lifting all the legs on all the components It still testing S/c on SN2,testing shows short between C+E on Q661 and short all three legs on Q662 the rest test good? so started to check Buffer ICs and found IC 4803 showing shorts all over . so here`s my problem, I am looking for some one to replace this IC for me. My eyes are not what they were I can supply the IC just need it fitted so if there is anyone in the UK that could help an old man out with this please message me Thanks FlockoTags: None
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by howardc64
- Prior owner tried a replacement main board. No difference.
- Samsung 2x red blinking standby LED = panel fault
- Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
- Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
- Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
by YanlebHi all,
I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer.... -
by Bad_BoardsBackground:
I have a LG 50PA550 Plasma TV which stopped displaying a picture. The sound works just fine. The outputs of the power supply board were within 2% of the expected values. After removing the Y top buffer the bottom half of the TV started working.
Question:
Do I have to order both a Y-Buffer and Y-Sustain board to fix this?
Could I somehow check the Y-Sustain board to see if there was any damage done to it? -
by the_remHello guys,
I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow... - Loading...
