TNPA5349 Buffer replacement
    Re: TNPA5349 Buffer replacement
    I repaired one a while ago (TX-P42U30B) and I quite liked it when working...
    • tw2005
      • Oct 2011
      • 6458
      Originally posted by flocko
      I have now started to go round checking on the pads were the legs have been lifted on the diodes + IGBTs to see if any show shorted there was a small Fet Q600 that I had missed but there is no short on that. I will also pull the 2 cap from across SN2 socket as well do you think that I am right about the test across the diodes by the buffers as these show short?
      the smd diodes next to buffers will sow short and is normal. you'd have to lft them if you want to be sure
      • tw2005
        • Oct 2011
        • 6458
        Originally posted by tom66
        tw, do you have a schematic of this board?
        as per NEELIX, by the time you enlarge it, too hard to read. I'm not understanding how a shorted buffer chip can short sn2. I experimented with shorting vfo to vfg on a X20 Sn and did not cause sn2 to short
          Didn't you have one from Brazil...? will have to dig it out...
          • tw2005
            • Oct 2011
            • 6458
            I have 50", GT30 went looking for 42", maybe I just don't see it
            • flocko
              • Nov 2012
              • 1121
              • uk
              #26
              Thanks guys ,I will be back on to this late this afternoon, have to go out this morning. But anything you think could help me track down this short, or any tips for removing the buffer cleanly on these new Panasonic boards please post here Flocko
              • flocko
                • Nov 2012
                • 1121
                • uk
                #27
                Well the buffer removal did not go to well lost two tracks, tried to put up photos but for some reason it will not let me. anyway the short remains on SN2, I can only put so much time into this board,I would have liked to fix it but will now put it to one side and come back to it later, but will also keep a eye open for a replacement board, thanks for all the help, I will keep you updated if I find the short Flocko
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  #28
                  Good luck finding one that is affordable or worth it, They are as rare as rocking horse crap believe me as I am hunting one myself.
                  Mine had had a previous repair attempt before I purchased this set and it did not go well for the board, Torn up tracks and pads, multiple shorts blah blah blah All my IC's are fine so may well try and get it repaired if i cannot source an affordable replacement.
                  Also sorry I have not been on for the last week as I have a IR rework machine here
                  • tw2005
                    • Oct 2011
                    • 6458
                    blessed are those who can do this. how did you go with that sealant removal?
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      #30
                      If i remember right Acetone will eat sealant
                      • flocko
                        • Nov 2012
                        • 1121
                        • uk
                        #31
                        it was the silicon that done for me, you can only get off what is over the pins but it must be very fluid when its put on, as it seeps right under the chip, used hot air and lifted it in one corner and then flipped it on its back, but you could see the tracks had been pulled up by the silicon as went over it was the last part to let go that pulled the tracks, I keep trying to load photos but don't seem able to. Newtothis the boards are out there you just have to know were to look? Flocko
                        • tw2005
                          • Oct 2011
                          • 6458
                          yeah, and that was the point i was trying to make about getting all the silicone off. When i had a go I cut the pins against the chip, then got the ic off , no issue( took a lot of force)but I still had some sealant on the pins and it was that that grabbed the tracks as i was desoldering the legs and tore the tracks.
                          have you checked the size of the photo, not larger than 2000 x 2000, that will stop it uploading
                          • flocko
                            • Nov 2012
                            • 1121
                            • uk
                            #33
                            Hi TW Yes I cannot say I was not warned, but I would not think these two missing tracks would make the board a right off, as you can see were they go to on the ribbon socket ,its more the short that is the time killer trying to find that, I could try the old trick of putting some volts though it and watch for the smoke (24v Truck battery)? the photos are stills from the microscope but just wont download on to here Flocko
                            • tw2005
                              • Oct 2011
                              • 6458
                              The short has me puzzled, that's for sure. No photo is a real tease. so what format is the still and what's it's dimensions ?
                              A truck battery, hope not direct to it, it has enough current to vapourise anything, i think you'd want to limit the current somehow. I've never experimented applying voltage to a short to find heat
                              • flocko
                                • Nov 2012
                                • 1121
                                • uk
                                #35
                                Sorry TW that is just my cockney sarcasm the bit about the truck battery, I used to work as signal tech on the London underground ,on the ticket vending side (auto fare collecting) and each station had a room full of coding and decoding equipment, That magnetically encrypted a code to the back of the ticket, that was read by the auto gates as you passed though, this was so complex that when things went wrong find the faults were a big problem, and I was the only tech and on call for the Victoria line (was new then)and Bakerloo line. When a tech on another line ask one day how I checked for shorts I told him with a truck battery (as a joke) and he burnt out about four miles of wiring and nearly burnt down the strand station Happy days Flocko
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  hard to pick the sarcasm in text. no joy with the photo i guess?
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
                                  • howardc64
                                    by howardc64
                                    Problem
                                    08-04-2024, 10:36 PM
                                  • howardc64
                                    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                    by howardc64
                                    • Prior owner tried a replacement main board. No difference.
                                    • Samsung 2x red blinking standby LED = panel fault
                                    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                    07-19-2025, 10:54 PM
                                  • Yanleb
                                    Schematic or datasheet for Plasma TV buffer chip
                                    by Yanleb
                                    I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                                    So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                                    Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                                    05-18-2022, 01:36 PM
                                  • reformatt
                                    by reformatt
                                    07-31-2025, 08:37 PM
