Samsung 32" LE32C450E1W TV unusual Fault
  • Sean D
    • Feb 2015
    • 5
    • United Kingdom
    Hi< I have the above TV and it has an unusual fault, It runs perfectly normal until I use any of the menus, shortly after the menu is displayed a vertical red line appears near the left hand side, if I leave the menu up the line gets deeper in colour and spreads across the screen, any help would be appreciated, I have done a factory reset and cleaned the LCD ribbon
    Thanks in advance
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung 32" LE32C450E1W TV unusual Fault
    Could you take some pictures please, it sounds like a bad lcd panel.
    • Sean D
      • Feb 2015
      • 5
      • United Kingdom
      I will put some on soon as my camera battery is flat, forgot to mention that if the Tv is turned off and on its fine again until I enter the menus
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Sounds like a bad panel, what is the panel used in this tv ?
        • Agent24
          I see dead caps
          • Oct 2007
          • 5037
          • New Zealand
          Weird. What if you try sending it a test pattern that looks similar to the menu?
          -David VanHorn
          • Sean D
            • Feb 2015
            • 5
            • United Kingdom
            How do I send a test pattern, I will get some pics up soon
            • Sean D
              • Feb 2015
              • 5
              • United Kingdom
              This is after 20 seconds of the menu being pressed
              This is about a minute later
              I found that once the menu is off the red line fades away after about 2 minutes
              • Agent24
                I see dead caps
                • Oct 2007
                • 5037
                • New Zealand
                Hook it up to a computer and display a similar image or such, perhaps?
                Weird that it only shows up with the menu and goes away after... At first guess that would make me think something is wrong with the logic board, but then perhaps a bad panel\driver etc might be responding to that specific kind of picture.
                -David VanHorn
                • howardc64
                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                  by howardc64
                  • Prior owner tried a replacement main board. No difference.
                  • Samsung 2x red blinking standby LED = panel fault
                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                  07-19-2025, 10:54 PM
                  09-07-2024, 05:50 AM
                • Robby-Gr
                  TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                  by Robby-Gr
                  I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                  However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                  The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                  Additional issues:...
                  09-27-2025, 12:02 AM
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
                  09-06-2024, 11:40 PM
