and yet another Samsung 400 series plasma panel bad
  • freakaftr8
    • Oct 2012
    • 3743
    just picked this one up with a broken HDMI connector which was shorting out the main board. I had a main board here and it was from a insignia model Samsung knock off. Had to modify the back cover a bit to make it fit but however after powering it up I thought I had a perfect 720p picture but long and behold I'm presented with vertical lines on the screen. just lovely. why the hell did Samsung cheap out under Walmart Samsung models with their 720p panels? X buffer IC's or just horrible. Very little active cooling in one small aluminum bar going across the bottom that they're all attached to be cool them off.. this is the fourth or fifth panel I have run into the same problem. This TV is a pn50B400.
    I can't sell this piece of crap. I just get to sit here and watch it grenade
  • freakaftr8
    • Oct 2012
    • 3743
    Re: and yet another Samsung 400 series plasma panel bad
    oh and by the way you know what the funny thing is? this mainboard that came out of its insignia counterpart that panel had the same problem except way worse it was just filled with lines and one chip on film was actually smoking. Way to go Samsung
    anyway thet panel of doom is a model S50HW-YB05. so anybody runs into one of these TVs to repair for the possibility of resale run from it as fast as you can
      The B-series has been very problematic for Samsung. Of all vendors, panel failures are most common on Samsung -- LCD or plasma. It's probably because Samsung's attitude to warranties is to ship the customer a refurbished TV, more often than repairing their TV. But, at least the Y-main is worth a little, I believe, as it is a common failure.
      • freakaftr8
        • Oct 2012
        • 3743
        Good to know. I have two of them.
          At least you can have fun. Take off the X-buffer heatsink, see how long it lasts... I'd be interested to see a Sammy PDP self destructing...
          • freakaftr8
            • Oct 2012
            • 3743
            actually Tom I did this with The insignia version of the Samsung that I pulled the main board from for this one. I was thinking just like you at the time I had one before go up in smoke another one lasted about 5 minutes and funny thing is when the TV was on with a white full screen haha all of a sudden I start getting random color lines all over the screen popping up over a five minute span.
            Eventually one of the ribbon cables smoked so bad it Shut down and it started clicking on and off in a reset. this was being caused by a direct short to VA to ground. I wish I would have taken a video of it now. It was about a year ago. by the time it decided to short out and start shutting the power supply down there were black lines white lines red lines blue lines green lines purple lines and black bars spanning about an inch wide all over the screen it was completely jacked up. the funny thing is you could smell it burning in the atmosphere they had this really toxic plastic burning smell it was weird. during the 5 minute span near the end the power supply was shut down like every 30 seconds and come back on while VA ribbons wpuld momentarly short to ground until it finally died completely
            • freakaftr8
              • Oct 2012
              • 3743
              I firmly believe that if they did a better job with the heat sink for these X buffers these panels would not be having a problem. The problem is is that down in the bottom of the TV space is extremely compromised so they cut down on the amount of heat sinking for these Buffers. when I look at any other 50 inch PDP panel the heat sink is moderately big thick and built well this one is a strip of metal
                Haha sounds amazing, I might just have to do it myself on a bad panel sometime.
                This is a bit more extreme:
                https://www.youtube.com/watch?v=mkvQ9aWM0DE
                • freakaftr8
                  • Oct 2012
                  • 3743
                  omg!! freakaftr8 currently is looking in the garage for the old arc welder transformer! Haha
                  • Shinju
                    • Mar 2014
                    • 1239
                    Awesome! I had to watch it a few times!
                    Lets crank it to the max... ABSOLUTE POWER!
                    • Biruslapio
                      Samsung's AU series "high quality" panel internally melting
                      by Biruslapio
                      I got this 55 inch AU7X00 TV, it was rebooting and showed no image only a blink of the backlights.
                      I assumed it was either panel or motherboard. Turns out it was the panel, and after applying some tape on the ribbon cable that goes to the left side of the screen, the TV turned on with image, then I suddenly noticed a dark spot and the pixels were turning black on the left edge, I was sad and thought I smashed the screen somewhere, found nothing visually, it looked in perfect condition and if it was there before it would've been noticeable while I was inspecting the TV the first time....
                      07-12-2024, 10:08 AM
                      09-07-2024, 05:50 AM
                    • triplefour
                      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                      by triplefour
                      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                      tcon is built into mainboard.
                      Only one cable goes to panel boards.
                      there is a cable from one panel board to the other that links them.
                      cost cutting measure that results in us having harder time to diagnose.
                      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                      07-28-2022, 07:59 PM
                    • NWArkGuy
                      Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                      by NWArkGuy
                      Well, I will be the first to admit that I screwed up...
                      In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                      I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                      I have 2 that I have found and have in my possession. ...
                      10-12-2023, 10:13 PM
                    • KYBOSH
                      Samsung UN50TU8000 - Dead Panel Forensic Questions
                      by KYBOSH
                      I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                      When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                      When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                      Later I checked for shorts on the panel PCB boards but could not find anything.
                      When I took a look with the FLIR i noticed the 2 resistors...
                      08-10-2024, 08:39 AM
