Philips 42PF521D/37 4 BLINK CODE
+ More Options
Posts
  • cadar21
    • Oct 2010
    • 53
    i bought this tv .. wouldn't turn on... opened the back N someone had tried to fix it.. It was missing capacitors... 3-to be exact ..1 was 680u-50v
    the other 2 were 3300u -50v.. i replaced those and then went to turn the tv on..4 blink code upon wondering what went wrong i removed the cable to the main board on the left (Samsung LJ92-01200A (LJ41-02759A) Y-Main Board) and i see that there are 2 caps missing... Does anyone have a schematic to tell me what they are..
    i need C5052 AND C5040....
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Philips 42PF521D/37 4 BLINK CODE
    Are you sure you wrote down the right type of the tv? Cant find anything about Philips 42PF521D?
    • cadar21
      • Oct 2010
      • 53
      Sorry your right forgot the 3.. Philips 42PF5321D/37
      • cloo
        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
        by cloo
        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
        After doing a factory reset this problem was gone and the picture was back to...
        01-06-2025, 06:02 AM
        LCD LED TV Service Menu Codes
        ALL LCD LED TV SERVICE MENU CODES
        Service Menu Code with Board Name
        China Universal Board / Jumper Board Service Menu Code
        Changhong Ruba Service Menu Code
        Ecostar LED TV Service Menu Code
        Orient LED TV Service Menu Code
        Haier LED TV Service Menu Code
        TCL LED TV Service Menu Code
        Samsung LED TV Service Menu Code
        LG LED TV Service Menu Code
        Videocon LED TV Service Menu Code
        Supra LED TV Service Menu Code
        Toshiba LED TV Service Menu Code
        Symphony LED TV Service Menu Code
        Veste/ LED TV Service Menu Code...
        10-31-2024, 03:58 AM
      • eurgenca
        Philips TV 43pus7505 setting display option code, help please.
        by eurgenca
        Hello.
        I am dealing with a Philips TV, 43pus7505 and is stuck on boot loop.
        So I ordered a used CPU board, and now I have wired picture.
        I think the problem lies in display option code. According to SM, the command for setting
        display code is 062598 + MENU + 032 (032 is written on a label on back of a TV).
        But as soon I press the menu button TV jumps in menu. Can someone please tell me what I am doing wrong,
        or can I manually edit option code in SAM.​
        10-07-2024, 02:09 AM
      • rmacintosh
        Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
        by rmacintosh
        I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
        The symptoms of the tv ar as follows:
        • Plug AC in to back of TV
        • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
        • The 3 blink code is given by the power LED
        • If the TV is unplugged and then
        03-14-2020, 12:24 AM
      • Dvsr
        Philips 55PFL8008S/12 two blink error code
        by Dvsr
        Hi. This noob needs help with this TV.
        Symptoms: TV haven't always turned on but when it has, it has been working normally. The TV was sitting in the storage for about an year and after that time for a few days it worked perfectly and turned on every time. But then it suddenly won't turn on anymore and just shows two blinks with standby light.
        I disassembled the back cover and examined the circuit boards. I didn't notice anything obvious with PCBs and components. I measured the voltage rails. In the connector that connects to logic board every voltage is present and...
        02-05-2023, 10:36 AM
