Power, but no video on LG 60PN5700 Plasma flat panel
  • SurrealMustard
    • Jan 2015
    • 486
    • The United States of America
    Part
    Originally posted by capkid
    I agree with Tom: Looks like a bad YSus. I'd try the logic control board test that Tom mentions in post #5, just to cover all bases. The logic board is the small one in the middle of the panel.
    How would I go about doing the Ext Autogen procedure that was mentioned there? I replaced the Y sustain and am getting the same symptom (power, screen lights up, nothing on the screen). This time, the VSC is holding steady at around 140-145 though.
    • capkid
      • Oct 2010
      • 1339
      Re: Power, but no video on LG 60PN5700 Plasma flat panel
      Here are some instructions from Tom. A paperclip would be an OK jumper: https://www.badcaps.net/forum/showpo...01&postcount=8
      LG Plasma Mal-Discharge Correction Service
      • SurrealMustard
        • Jan 2015
        • 486
        Misdiagnosis
        Nuts, I wish I would've seen that before I replaced the Y Sustain. The paperclip trick not only yielded a picture with the new sustain board, but with the old one as well. And yikes, are those main boards ever expensive!
        • capkid
          • Oct 2010
          • 1339
          Yeah, that's one reason Tom and I mentioned checking the control board earlier in your thread - to avoid just throwing parts (money) at the TV. It appears that there are a couple variations of the main board. Which one do you have installed? Someone here may be able to help you find one at a good price.
            Main boards are definitely LG's Achilles heel. Otherwise they're not too bad for reliability.
            • SurrealMustard
              • Jan 2015
              • 486
              #26
              Repair
              So even with the test pattern being displayed properly using the paperclip trick, I could still have a bad Y Sustain?
              And they're a bit on the expensive side too.
                As long as the patterns look ok your Y-sus is almost guaranteed to be ok.
                • SurrealMustard
                  • Jan 2015
                  • 486
                  #28
                  Sustain
                  If the board was okay, what could've been the cause of the unstable readings? Could there be a meter issue?
                    Re: Sustain
                    Main board could be turning panel on/off causing that, or perhaps your Y-sus was bad before but the replacement is ok? (two boards could be bad, e.g. power surge damage.)
                    • SurrealMustard
                      • Jan 2015
                      • 486
                      #30
                      Fixed!
                      Just to provide some closure here, after mainboard replacement, the television is now working. Hooray!
                      Thanks everyone for the tips. Hopefully my mistakes will help someone else who might have the same problem.
                      • capkid
                        • Oct 2010
                        • 1339
                        Nice. Glad it's working again.
                        • Rogue110
                          • Feb 2016
                          I found this forum and it seems similar to my issues, but I am having one trouble after the next.
                          So it started when we were watching tv (near the fireplace) and heard a crack and the picture went out. Completely dead and no standby light. I opened the TV up and found a capacitor (not a bulk but a small ceramic) damaged as though it had popped as well as the fuse was bad. I tried replacing the cap and the fuse, but same issue. So I replaced the power supply. The new power supply worked fine and was not blowing, but the standby light would randomly come on if I plugged power in, and sometimes would not come on until I unplugged power. If I pressed the power button when the standby light was on, the standby light would turn off, but nothing else. So I replaced the main logic board.
                          So the new logic board is in and the tv will power up, but only with sound. Volume on the remote and power commands work, but sound only. I have tried unplugging YSus and ZSus, but exhibit the same failure of sound only. None of the heat sinks on the Y or Z sus get warm while the tv is on. For the measurements requested earlier I am getting:
                          (1) PSU: VS (204V) and VA (54V)
                          (2) YSus: VSCAN (0-8V)
                          (3) ZSus: VZB (72-78V)
                          I also tried the EXT_AUTO_GEN short and this did not create a picture. The screen is not cracked, but I am starting to wonder if there was some sort of large scale issue that took out multiple boards and the screen itself. Any thoughts??? Time to give up?
                            HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                            This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                            09-12-2024, 02:00 PM
                          • KYBOSH
                            VIORE PDP4210EA Plasma TV 42 inch - No Video on DVI
                            by KYBOSH
                            Got my hands on an relatively unknown TV brand about two weeks ago.
                            I certainly hadn't heard of it before.
                            Previous owner didn't give a description of what was wrong and when I got it the back cover was already off.
                            I put it on the back burner until I had so spare time to look it over.
                            Today was that day.
                            I plugged it in and was surprised to see that it started up without any issues.
                            This is an older TV and the most modern video input that it has is DVI.
                            I was scrambling to find a DVI connector or adapter as I haven't fooled with that...
                            01-27-2023, 08:19 PM
                            GeForce RTX2080 Super Aero video gaming card issues help need
                            by sam_sam_sam
                            This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                            Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                            05-07-2023, 08:12 AM
                            HP EliteBook 850 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 850 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 850 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                            09-06-2024, 06:20 AM
                            HP ProBook 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 400 Specification for Upgrade or Repair
                            This specification for the HP ProBook 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
