Panasonic TH-42PX70BA 7 Blink,--SOS 7 Fixed.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Above set dead apart from seven blink of red std-by lamp.
    Checking the manual suggests that the Inverter for the various supplies on the SC board is unhappy.
    Disconnecting both buffers from the SC completely, and set runs.
    Reconnected bottom-buffer only, back to SOS-7
    Disconnected bottom buffer re-connected top buffer, set runs with half a picture proving bottom buffer bad.
    --A short was found in one of the chips of the bottom buffer.
    TELEFIX
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Andre Gilbert
    by Andre Gilbert
    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
    11-20-2024, 08:52 PM
  • Yanleb
    Schematic or datasheet for Plasma TV buffer chip
    by Yanleb
    I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
    So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
    Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
    05-18-2022, 01:36 PM
  • howardc64
    TCL 49S405 double image
    by howardc64
    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
    06-23-2025, 03:20 PM
