samsung ps-42c96hd totally dead
    Re: samsung ps-42c96hd totally dead
    Could be blown that would cause screen glow with no picture (can also be bad panel if shorted and blew Va fuse)
    • sordids999
      • May 2013
      • 2160
      • uk
      ok well i have a replacement screen so ill try and swop all the parts over to see what i get ill post the results later
        We've seen a few Sammy plasmas on here with that fuse blown, replacing usually fixes issue. if you change panel try changing control board with it (as the control board has ageing data to compensate panel drive over time.)
        • sordids999
          • May 2013
          • 2160
          • uk
          ok tom ill try the fuse first
          • sordids999
            • May 2013
            • 2160
            • uk
            changed the fuse still the same and no voltage reading from the fuse
              What do you have on each end of the fuse, volts wise, red probe on one end, black on the chassis, TV powered up.
              • sordids999
                • May 2013
                • 2160
                • uk
                #27
                just changed the panel over quickly exactly the same fuse on replacement screen buffer is 63 volts both ends
                • sordids999
                  • May 2013
                  • 2160
                  • uk
                  #28
                  im putting the old screen back in im thinking i measured the original fuse wrong i was testing both ends not using red probe on one end, black on the chassis
                    You got 63V both ends but no picture?
                    • sordids999
                      • May 2013
                      • 2160
                      • uk
                      #30
                      yes 63 volts both ends but still no picture just a glowing screen
                      • sordids999
                        • May 2013
                        • 2160
                        • uk
                        #31
                        checked the control board fuse both ends im getting 5.23 volts
                          Can you post a pic of your control board?
                          • sordids999
                            • May 2013
                            • 2160
                            • uk
                            #33
                            Thats my control board tom
                              Ok, put a wire jumper across pins 3 and 4 of CN2023, disconnect the LVDS cable and power the TV up. Does it show test patterns?
                              • sordids999
                                • May 2013
                                • 2160
                                • uk
                                #35
                                no tom no test patterns
                                  That is odd. I am beginning to suspect bad control board or possibly panel. Can you swap the control board?
                                  • sordids999
                                    • May 2013
                                    • 2160
                                    • uk
                                    #37
                                    i dont have a control board spare just typical i have a xsus,panel but sold the rest but dont forget i swopped the parts into the other panel today and it was exactly the same
                                    • sordids999
                                      • May 2013
                                      • 2160
                                      • uk
                                      #38
                                      Just typical sourced a tcon roughly 40 to 60 quid so maybe I'll sell the parts and thats now a C and Q version of panels to my collection
                                      • nikospot
                                        • Dec 2014
                                        • greece
                                        #39
                                        Hello, I am terribly sorry for hijacking this thread, but as I was looking for my problem I found this that I think is somehow related to my problem. Is it possible for someone to help me in this thread?
                                        I have the same TV but it has no picture at all. Sound is ok and I am changing the channels and hear at the TV. Voltages were ok except Vs. So I tried disconnecting Y-main from PSU to see if the PSU will give the Vs voltage (I thought maybe I had a faulty y-main and for protection the PSU wouldn't start the Vs). No luck with this, so I removed the PSU and forced it to turn on. Also I forced the Vs voltage (I read it at this forum but from another topic I can't find now) by putting a 500Ohm resistor between two pins on the PSU (I can't remember which of them because there has been many days since then and don't have the PSU available now). The Vs started normally so the PSU was fully working by forcing it.
                                        My conclusion was that maybe the t-con board is dead because it is the only board I see the PSU is connected to get the command to start the Vs voltage.
                                        So shall I try it? Or am I wrong and should try something else?
                                        But I have to tell you that after all of the above I think I did something stupid that may caused more problems to the TV. I forced the Vs voltage to start with the PSU connected on the TV with all the boards on it. The good thing was that all the voltages were fine, even at the Y-main and Y-buffer, but if the PSU wasn't starting for protection I may broke down something else.
                                        Thank you very much!
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
