Daytek DT-4640
  • colorless
    • Jul 2013
    • 25
    • canada
    Daytek DT-4640
    I got a daytek dt-4640 LCD TV that would not power on, opened it up and found a blowen cap on the secondary side of the power supply I recapped the secondary side and now when I turn it on the power led goes green for a few seconds the turns red blinks once then a pause then three times another pause then twice and then blinks very fast and repeats, any one know what that fault code might mean? I have been unable to find any info on this TV. It uses a Samsung panel. Any help would be great just have not spent a lot of time on it yet.
  • drussell
    • Nov 2014
    • 144
    Re: Daytek DT-4640
    https://www.badcaps.net/forum/showthread.php?t=39740
    Also, please measure all of the voltages from the power supply and report what you're seeing on each one.
    • Biruslapio
      Panasonic P58V11B 8 and 12 blinks error "fix"
      by Biruslapio
      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
      04-13-2021, 07:13 AM
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • Taurus12
      Optiplex 3050 micro 2 blinks followed by 3 blinks issue
      by Taurus12
      Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
      I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
      i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
      Any recommendation on what I have to do next? Thanks in advance
      06-10-2025, 05:05 PM
    • jchon
      Sony A1e 5-blinks help
      by jchon
      Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
      I found the service manual, which was critical to know where to probe.
      https://www.manualslib.com/manual/20...1e-Series.html
      With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
      Unfortunately the 5-blinks...
      06-28-2023, 11:52 AM
    • mmischni
      Panasonic Viera Plasma TH-42PX75U 7 Blinks/8 Blinks/burned P board?
      by mmischni
      Greetings friends,
      I have a Panasonic TH-42PX75U manufactured in 2007. It has been trouble-free until recently. One evening I turned it on and it then powered back off and gave 7 blinks.
      First a question about the blinks. Everyone only speaks of a single number of blinks. I noticed on my TV, it blinks one fewer times for the first group of blinks, then blinks the full number repeatedly. So for my first code in question, the TV switches off, blinks 6, then blinks 7 repeatedly. When I disconnected the SC board, the TV switches off, blinks 7, then blinks 8 repeatedly....
      09-06-2017, 08:52 PM
