Samsung ps50q91h clicking noise, no image/sound
  • Neverzinho
    • Jul 2014
    • 14
    • Portugal
    Hello
    I have a Samsung ps50q91h 50" Plasma from 2007, it just does a clicking sound, trying to boot up.
    I've already replaced the capacitors, one was leaking but not buldged and the others were a little bit buldged.
    Still the same problem, please see this video with this problem, the noise it seems to come from those 2 blue components or the black ones.
    https://www.youtube.com/watch?v=3hqK1dPcug0
    Any ideias?
  • tw2005
    • Oct 2011
    • 6458
    Re: Samsung ps50q91h clicking noise, no image/sound
    These have some common faults. Endless clicking could be bad or cracked solder joints on the heatsinked transistors etc or they have blown already due to this and psu will need rebuild. If you search the board part number in badcaps good chance you will get some good posts to read.
    It will be bn44-........ on the white sticker
    Other issue these have is theymain and uppet buffer blows
    I have one that blew the ymain buffer and psu in one hit or maybe the psu blew aftr repeated attempts with bad ymain.
    • wolf1976
      samsung ue40d6100 has no backlight no sound and image
      by wolf1976
      hi to all
      on the above model of samsung i have the faults i have told already on the title
      iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
      any idea from someone what can i measure so i can find the problem ?
      the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
      11-17-2024, 01:02 PM
    • Sisko
      Onkyo-593 No power and now clicking sound
      by Sisko
      Hi all!!
      Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
      10-03-2025, 02:18 PM
      09-07-2024, 05:50 AM
    • Francesc V.
      Samsung UE48J6200K - No image but sound
      by Francesc V.
      Hi:
      This TV turns on and it can show picture for some seconds (sometimes minutes) then picture freezes and fades away. What I've seen so far is that the T-Con (BN41-021101A) starts with three leds on, but as soon as led3 turns off, just 12V and 3.3V (the bold ones) remains in the PCB but all others disappear.
      If I remove the 2 bellow ribbons, LED2 never turns on. I was trying to look for the "T-CON ready" pin to shorten with 3.3V and then test just the TCON without the panel (haven't found it yet)
      Not sure how to proceed here..............how can...
      10-09-2024, 07:01 AM
    • slimmy182
      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
      by slimmy182
      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
      Looking on google I found this:...
      01-14-2023, 11:55 AM
