Philips 37HFL5880D blocked in stand by
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    that LCD is blocked in stand by.
    Attached the schematic, any suggest?
    Tks in advance
    P.
    On connector 1M95 have 3.3v and 12v at pin 1 and 6-7-8 at pin 2 have = volt also when press power on butto on local command.
  • blablaro
    Philips PSU (715G7350-P01-000-002S) No stand by light (0V)
    by blablaro
    This is the source from a Philips TV 43PUH6101 that suddenly stopped.
    I know it's the source since I have ~ 0 volts on outputs 12VA/16VA, 12V/16V, +3.5/+5V
    For the latest weeks I've been trying to figure out the problem with this. I've ordered all kind of mosfets, a capacity meter and other things to try to figure out the issue with this PSU. My wife thinks I'm crazi but I want to repair it
    Initially, when I started the testing with the multimeter on diode mode (220 V on):
    - discovered that was Q9101 shorted (or I shorted it)
    09-24-2025, 10:21 AM
  • DXseekerMO
    Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
    by DXseekerMO
    Hello everyone!
    Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
    Symptoms:
    1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
    2) TV does not appear to turn on
    3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
    4) "Power on" terminal on Power Supply has 3.26v
    5) "A13V" terminals have 12.9v
    6) Stand-by test jumper on Power Supply has 12.9V
    7) Optical audio jack on Main Board illuminates
    8) With stand-by...
    06-09-2021, 12:19 AM
  • digitel
    Philips BDP5180/12 Blue-Ray "logo" in image. blocked
    by digitel
    hi
    The device is connected via HDMI to a TV. It turns on with the power key and the "Logo" appears in the image; but the device does not respond to any order from the control and/or keyboard.
    Does not open tray.
    Not even the front display lights up.
    Voltages in the connector from the source to the main are correct, according to serigraphy.
    Voltage from the connector to the front display, they are fine.
    Display filament powered.
    BGA memory ICs have a temperature between 36 and 39 degrees Celsius.
    I have not tried to update...
    11-25-2022, 11:59 AM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • FriedFred
    Schenker VIA 15 PRO, PF 4NU1F V1.0, P/N: MBPPF4NU18-F310 - 36mA in stand-by
    by FriedFred
    Hello, everyone!
    I have here a Schenker VIA 15 PRO, with this numbers on the board: PF 4NU1F V1.0 and P/N: MBPPF4NU18-F310 .
    I took out the memory and the battery and the SSD.
    So, in stand-by, only the board, takes 36mA. No power-button pressed at all, I can measure 1.8V, 3.3V, 5V. All coils present voltages except the two power rails for the CPU. The CPU is a AMD Ryzen 5 4600H.
    After pressing the power-button, the current raises to 500mA and the two power rails for the CPU show up with 0.8V.
    After several seconds, the fans switch-off and the board keeps powered...
    03-08-2025, 04:45 AM
