Samsung Vertical Lines
  • singledad30ca
    • 9
    Are these lines because the screen is damaged or could it be the T-con board?
    My TV is a 40 inch samsung LN40A450C1DXZC
    Thanks for you help
    Re: Samsung Vertical Lines
    Failed panel sorry
    • singledad30ca
      • 9
      Figured as much.
        • 12128
        • U.S.
        had a jvc, when I took it apart down to the screen, noticed if the screws that hold the panel are too tight you get real thin lines, adjust the screw and they went away, but the different brands and models are probably all built in different ways.
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
          09-07-2024, 05:50 AM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • ItalianSat
          LCD SAMSUNG LE40A656A1CXXE - Vertical Lines on Half of The Screen?
          by ItalianSat
          Hello Everybody,
          I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
          Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
          Moreover, I detached the T-CON board for a new round of investigation. I personally...
          06-28-2022, 06:02 AM
        • afex
          Samsung Plasma TV with vertical lines (model PN50B430P2D)
          by afex
          This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
          This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
          I have attached an image of the TV with these bars displaying....
          11-08-2021, 09:23 PM
