Samsung LE32B530P7N....BN44-00234A
  • Andyd1970
    • Feb 2013
    • 374
    • united kingdom
    Hi Guys,
    Help!
    I have the above set in for repair, it takes ages to come on, red light flashes and sometimes it just flashes etc. I thought it was cap related so I changed the main caps and it still does the same, so I started to heat the PCB with a hairdryer and it comes on straight away, so I started to try to locate which part of the PCB was being effected by the heat, I used a piece of paper in like a funnel shape to direct the heat. I have attached a picture of the area that seems to be causing the issue.
    I replaced three of the small caps thinking it was them but it still does not come on straight away unless I use heat. I thought I was doing well as my knowledge has come on loads since I joined the site and repaired around 10 TV's for friends but do not want to be beaten by this one.
    Am I right in that as it is effected by heat it has to be cap related?
    Thank you in advance.
  • badwily
    • Jun 2019
    • portugal
    Re: Samsung LE32B530P7N....BN44-00234A
    If you have low voltage on 12v , like 8v or so. change the transistor (QB802) D526 TOSHIBA/FAIRCHILD TO-220 Transistor.
    Originally posted by Andyd1970
    Hi Guys,
    Help!
    • dskall
      • Oct 2016
      • 2905
      • usa
      Check all solder joints in the area.
      • R_J
        • 9623
        Hi Guys,
        I see 4 small electrolytic capacitors in that circuit, which 3 did you replace and why not the forth one?
        QB802 is a regulator/switch that supplies the vcc voltage to the pfc circuit, If the transistor is weak it can cause low vcc voltage to the pfc ic.
          • 12328
          • U.S.
          lol, did nobody see that this thread was made over 7 years ago?
          • R_J
            • 9623
            Nope. missed that, need to pay more attention, too bad threads this old were not closed after a period of time.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Doh!
              Well, Wisdom is timeless.
                • 12328
                • U.S.
                Well I wonder why andy didn't follow up with this, too busy huh andy?
                  • 12328
                  • U.S.
                  similar problem, heating that area brought the backlights on, switched out every cap in that area, still no boosted pfc, all voltages on connector, stby, 12 vols etc, are right on and steady.
                    09-07-2024, 05:50 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
                    Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                    This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 06:20 PM
