Y Buffer Question
  • smpstech
    • Dec 2014
    • 15
    • US
    Y Buffer Question
    Can I turn on the TV with the Ribbon cables disconnected from the display panel. Just the Y Buffer connected to Y Main and the rest of the Circuit. This is on a Samsung.
  • MagicSmoke
    • Feb 2011
    • 275
    Re: Y Buffer Question
    Usually Yes you can, unless it's a newer model.
    I have a Samsung pn60e550 that has a fault detection on Y main.
    If everything is not hooked up and working it will shut down and not make VA volts.
    • smpstech
      • Dec 2014
      • 15
      • US
      I see, now that I think about it, it does shut down. Thanks for the info.
        09-07-2024, 05:50 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • howardc64
        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
        by howardc64
        • Prior owner tried a replacement main board. No difference.
        • Samsung 2x red blinking standby LED = panel fault
        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
        07-19-2025, 10:54 PM
      • JSin21
        Compatibility of main boards between different variations of samsung MU6100
        by JSin21
        Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
        I have Samsung Smart TV UA65MU6100WXXY version DA01
        Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
        11-27-2023, 04:54 AM
