Samsung LN-T4061F: Power On Issue
  • RVC
    • Nov 2014
    I'm new here and glad to be a part of this component level community. Some members have posted here previously regarding my or, similar issues. These 3 threads can be reviewed here:
    https://www.badcaps.net/forum/search...archid=4151258
    My concern is I do not want to simply replace the two capacitors I see that have bulging tops (582 & 583). It has been clear to me that VR's can also be involved in this repair so, I want to ensure I have the correct voltage before naively replacing these two capacitors. My LN-T4061F began exhibiting this power on problem only late this summer because, we do not use the set much despite purchasing it in 2008.
    I am looking for measurement suggestions (TP's, etc) and parts recommendations. Additionally, I am also hoping someone here can openly discuss the Metcal soldering stations because, this is what I prefer to obtain but, I think the MX-500 is out of reach so, I need to restrict my attention to the SP-200 and possibly the Thermaltronics replacement hand sets.
    Thanks for the help,
    Rick
  • Kjell
    Samsung Series 9 - BIOS issue
    by Kjell
    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
    08-01-2025, 09:15 AM
    09-07-2024, 05:50 AM
  • Nairolf
    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
    by Nairolf
    I have a Samsung DM32D display.
    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
    Here’s what I have tried so far:
    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
    From these tests, I suspect the problem might be on the mainboard. Could anyone...
    08-24-2025, 03:47 AM
  • vincentedel
    Samsung SyncMaster 740n Phase Control Issue
    by vincentedel
    I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
    I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
    04-22-2025, 12:33 AM
  • Manucsl
    QE65Q800TATXXC Samsung TV Issue
    by Manucsl
    Hello.
    My TV is a QE65Q800TATXXC Samsung TV.
    Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
    Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
    Any ideas to check would be very appreciated 😊
    After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
    02-19-2025, 07:47 AM
