Samsung pn51d550C1fxzc plasma died, hope to fix
  • Hobb3s
    • Nov 2014
    • 9
    I have a Samsung pn51d550C1fxzc plasma (2 yrs old) that I believe has a bad x-main board. I was going to replace the whole board, but I can't source one, everyone is out of stock. So I've been reading through advice, troubleshooting methods, and common problems.
    It's my first time troubleshooting a circuit board, but I think I've narrowed the issue down to my X-Main board, and one of the mosfets on it (toshiba 30g124 to-220) after a little multimeter testing. I'm a newb at using a multimeter, but I think I found a short.
    I was just wondering if anyone has had similar experience with this model of television? or what their issue/repair was.
    As well, should I replace all of the mosfets of the same model with new ones, or just the one I think is shorted?
    Is there anything else you would recommend I replace a the same time?
    One more question, I have been able to find the similar board with different revisions 1.2 & 1.4, would those work or is the revision important to proper operation?
    The suspected dead x-main I have is this:
    Model: 50'dh/df_XM
    PCB: lj41-09422a
    rev r1.3(11/06/20)
    lj92-01759a
    lj92-01763a
    Thanks!
  • Michale32086
    • Nov 2011
    • 1453
    Re: Samsung pn51d550C1fxzc plasma died, hope to fix
    If you can post a picture of the board in question, I might be able to dig up a replacement... I have a ton of plasma TVs flying around....
    Michale
    • Hobb3s
      • Nov 2014
      • 9
      Here are some pictures of the board. One I pulled off a site that sells them, and the other is a close up of the info off the board taken from my phone.
      Thanks for looking!
        Wow, this board is failing a lot. 4 or so posts in the same week?
        The IGBT is bad if shorted, but there may also be other IGBTs bad in the same area. Often the IGBTs are arranged in half-bridge pairs, a high and low IGBT for the sustain voltage, for example. If you find the low bad, you must replace the high, and vice versa, unless you can be certain they are all ok. It's usually simpler just to replace them.
        Also, I would always replace any driver chips which control the IGBTs, this is because in some cases the IGBTs can damage the drivers when they short. If this is the case, turning on the set with new IGBTs but old drivers would cause the new IGBTs to burn up, as they would be given incorrect gate drive. This will involve surface mount soldering work in most cases but it's relatively easy 1-layer PCB stuff, hard to do wrong.
        • Michale32086
          • Nov 2011
          • 1453
          Thanks for looking!
          That board looks REAL familiar... I am fairly certain I have at least 1 or 2 flying around..
          I'll be going to my shop tomorrow around 1400 EST.. I'll see what I can dig up and post here....
          Michale
          • Michale32086
            • Nov 2011
            • 1453
            Here's what I have...
            Can't vouch for it's functionality... PM me your shipping addy and I'll get it to you. If it works for ya, then just cover my shipping and we'll be square...
            Michale
              Michale, 'fraid that's a 720p board (probably PN51D450 or D490) and so probably wouldn't work in his 1080p set.
              However, I think it would be possible to convert the 720p board into a 1080p one with a few modifications.
              • Michale32086
                • Nov 2011
                • 1453
                I have a few more Samsung Plasma sets in one of my storage sheds.. I'll dig thru those...
                • Michale32086
                  • Nov 2011
                  • 1453
                  Nope, no luck.. That's the only one I have...
                  • Hobb3s
                    • Nov 2014
                    • 9
                    Thanks for trying.
                    I made the attempt to replace the fets I found shorted, but to no avail. I don't have the technical expertise to trouble shoot this board short of just replacing all the components. If I had more time I might, but my wife and the kids want our only TV back and working sooner than later. Now I have to figure out what to buy, obviously it won't be Samsung, I'm done with them.
                      What did you use to repalce the FETs? You must use exact replacements.
                      Also it's often advisable to replace the driver chip that controls the FETs.
                      • Hobb3s
                        • Nov 2014
                        • 9
                        I replaced the fets with the same part number as was written on them. Toshiba 30g124. I don't have enough experience to identify which ones are the driver chips that you're referring too. I've attached 3 pictures, one of the back of the board, one of the front, and one of the fets including 2 I replaced. If you could point me to the driver chips, that would be very helpful.
                        Thanks!
                        • tpiton
                          Sorry to jump the thread. I've read quite a bit on the forum andI cant find the answer to my question. Will a SAMSUNG X-MAIN BOARD LJ92-01759A, LJ41-09422A / that PN51D450A2D will fit in my tv that is a PN51D550C1F ? It's all the same part number and the same version
                          • rogerazambuja
                            • Nov 2014
                            • 88
                            • Brazil
                            I'm not sure, but I think D450 model is 720p, right? If so I think it will not work.
                              09-07-2024, 05:50 AM
                              09-06-2024, 11:40 PM
                              09-06-2024, 08:40 PM
                              Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                              This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 06:20 PM
