LG 60PZ550 Plasma Screen Blotches
  • jloktalGst
    • Oct 2014
    • 6
    First off, thanks for all the great info on this site. I had the fairly common problem of no screen, and was able to find the description of re-flowing the coil solder joints, and that problem was resolved. So now I have a picture, but it literally looks like someone poured black ink or paint from the top of the screen, (think the Sherwin Williams world logo). My biggest fear is somehow the screen got cracked, (and no idea how). Any thoughts from the folks out there?
    Re: LG 60PZ550 Plasma Screen Blotches
    It's likely a Z-sustain fault or a loose connection.
    Check ALL connections to the Z-sustain board, check the orange ribbons are FIRMLY seated in the connection blocks.
    Probably not a cracked panel, they usually don't show any light when cracked (a few exceptions apply but only on Samsung & Panasonic panels)
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      I agree with Tom , i have not seen a cracked plasma screen that lights up.
      • jloktalGst
        • Oct 2014
        • 6
        Thanks for the quick response. In checking the ribbon cable connection on the bottom of the board, I managed to break the latch. Any chance I can source this without getting the entire Z SUS. Also, looking on the web for the PN, none match what is in my set: EBR 73561701. This is what happens when I get in a hurry.
          Can you show us a picture of what you broke?
          • jloktalGst
            • Oct 2014
            • 6
            Here you go...I managed to break one of the latch pins on the connector clamp that allows it to pivot up. Now there isn't any way to apply pressure to the ribbon to hold it in place. The 1st pic is the broken 1, and the second is the way it should look....
              Bugger... that's probably a custom part. You might be able to shim it down with some strong tape. But not sure.... otherwise that would be a board replacement component.
              • jloktalGst
                • Oct 2014
                • 6
                That would figure....any idea if there is a PN cross from the number above? I have not been able to source that PN. Thanks again.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Uhm , its not broken off? Sorry for my english but the small white parts that hold the black part in place are not broken?
                  The black part is easy to put back in as long as the the white part on the left and right are still in place and not broken off.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    I've shimmed a few connectors like this, usually keyboard connectors for laptops but the same principle.
                    A piece of rigid plastic from discarded packaging, cut to the correct length and inserted will hold the ribbon cable in. A dab of hot glue either side or some tape over the top will hold it.
                    • jloktalGst
                      • Oct 2014
                      • 6
                      Thanks for the input folks. Moreno83, the black latch snapped an end off. diif, I'll try the plastic and glue trick. I'll let you know how it goes. Thanks again.
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • Alicat
                        Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                        by Alicat
                        Stopped by this site trying to fix my parents Panasonic Plasma TV.
                        Model number is TH-50PZ85U
                        Power comes on and the red power light stays on solid.
                        Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                        I also hear a few clicks.
                        I also think my parents said there was a thunderstorm and the TV failed after that.
                        Section 6 in the service manual talks about power and no screen,...
                        10-30-2024, 10:09 AM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
                      • Zelek11
                        Panasonic Plasma screen interference on left half of screen
                        by Zelek11
                        My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                        This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                        10-14-2022, 04:54 PM
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
