LG Plasma 60PK950 .. Powers on Sound ok
  • einscodek
    • Oct 2014
    • 3
    • US
    Hi, have a 60PK950 LG Plasma here behaving for 4 years and then decided not to.
    Top/bottom screen flickers when powered on and after a few seconds both halves go almost blank with occaisional few flickering horiz lines once in a while but the sound is ok.
    If I press the input button, the system input menu sometimes appears and is visible but the top half flickers on/off and the bottom half flickers on/off at different rates and after a few seconds back to blank screen with some occaisional flickering thin horizontal lines.
    Control board led looks like its blinking.
    Powers on and after a while also goes to standby..I've tested Va/Vs and both are within range. I think power unit is behaving ok.
    I've tested Vz on the positive side of the resistor against frame as ground.. the voltage is inline with expected so I suspect ZSUS is ok.
    Testing Vy and Vsc on either side of the resistor against frame as ground finds no voltage.
    Questions:
    1)Is this a bad YSUS you think?
    2)Am I testing the Vy/Vsc/Vz resistors correctly by using frame as ground? I do not see any onboard grounds..
    3)Since I do see the input screen for a few seconds before it goes blank on each powerup, doesnt that mean both Y buffers are ok or could they be struggling or is it all the YSUS?
    I assume if the buffers were bad they wouldnt even give a few seconds..
    4)I see fuses on these boards..but I'm used to the old fashion glass fuses with the wire inside.. if one of these new non-glass fuses blows how can you tell? Are these new fuses resettable or something?
    Regards,
    Eins
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: LG Plasma 60PK950 .. Powers on Sound ok
    A couple of pics of the boards inside the set will help identify the chassis model and jog memories as to what fails.....
    TELEFIX
    • einscodek
      • Oct 2014
      • 3
      • US
      I'll have to get my borrowed camera back and take some pics later but an inspection shows no blown caps. Its a fairly standard layout of LG plasma tvs from what I see on the internet. YSUS on the left connected to the buffers on the edge, power board in the center and ZSUS on the right.
      Any ideas based on the symptoms and voltages checked and my list of questions in general above?
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • LEECH666
        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
        by LEECH666
        Good day ladies and gentleman!
        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
        01-19-2024, 05:46 PM
      • KYBOSH
        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
        by KYBOSH
        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
        No picture but you hear the TV static (white noise) playing loud and clear.
        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
        But it seems they didn't get too far and just left it.
        When I first took a look I was amazed at how pristine the inside looked.
        Its as if the TV had been in a time capsule.
        Caps looked like they were just pulled off the self.
        Copper coils had no sign of corrosion on...
        02-01-2023, 11:10 PM
      • Christos Tsiligiannis
        Marian Trace Alpha sound card repair help
        by Christos Tsiligiannis
        Hello to the forum.
        My name is Christos, I am new to the forum here and i am posting from Greece.
        So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
        To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
        So i tried asking for a schematic from the company and they would not give me one. Instead they...
        11-18-2024, 05:26 AM
