TC-P55S30 7 blinks problem
  • Dagregsta7
    • Aug 2014
    • U.S.
    I saw a similar thread to the one I'm about to post but it was a different model number. Originally had 7 blinks, replaced sc board and i heard a loud pop and the set went into a 14 blink error. I then sent my original SC board in for repair as well as SD/SU boards. They fixed my SC board, no more shorts and they informed me that one of my two SU/SD boards were bad (can't remember which). So I then replaced the bad one before putting my fixed SC board into the set. I went to power on and i no longer get any blink code error but the set refuses to power on. I can hear a buzzing noise over some of the boards as if the tv is working, but i have no picture on the screen. I went from 7 blinks to 14 blinks to none. I'm getting frustrated and confused Any ideas of what might be wrong here guys? Thanks so much in advance!
    -Greg
  • tw2005
    • Oct 2011
    • 6458
    Re: TC-P55S30 7 blinks problem
    cardinal sin i'm afraid. Always check buffers before replacing the SC. It's tragic you found us after the fact, we would have kept you on the straight and narrow.
    Who did the Sc repair?
    Post a picture of how all the boards are hooked up especially the Sc,SD,SU
    Did you notice if an onboard green LED was lit whilst you had the buzzing?
    • Vebririon
      panasonic TX-P50V10E 6 blink led problem
      by Vebririon
      I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
      Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
      I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
      05-17-2025, 10:16 AM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • dclass-pro
      Hp DAOP5FMB6A0 blink caps/lock problem
      by dclass-pro
      Hi guys, I have an HP model 15s-eq1040nl main DAOP5FMB6A0 REV:A with a caps/lock 5 long 3 short led flashing problem, I tried to remove the battery and program a new bios and when I restarted it immediately worked correctly, the pc turned on and loaded the operating system.
      As soon as I turned off the pc and connected the battery, the problem reappeared... caps/lock 5 long 3 short led flashing again!
      the battery was dead, i charged it and it works fine, but the pc won't turn on again.
      What do you recommend me? Do I have to redo the bios or is there anything else to check?...
      05-08-2023, 12:46 PM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
    • Gibon378
      Problem with stopping audio and video for no reason
      by Gibon378
      PC Specs:
      • CPU: Ryzen 5 1600
      • GPU: GTX 1080 Palit JetStream
      • MOBO: ASRock ab350 PRO4
      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
      • PSU: XFX 650W (don't remember what model)
      • OS SSD: ADATA SP920
      • OS: Windows 10 21H2
      Problem description:
      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
      11-19-2022, 09:41 AM
