Samsung PN50C550G1FXZA - Dark Display with ''Sparkles''
  • HamSa1ad
    • Oct 2014
    • 28
    Hello BadCaps Community!
    I have a Samsung PN50C550G1FXZA which suddenly began showing a dark display with what appears to be a form of sparkles down in the lower right-hand corner (when facing the display). The image actively changes when I swap around inputs, but does so with what looks like a strong image burn. I had previously received some information that led me to replacing the X-Main, but doing so has led to no change in the display.
    When the issue originally occurred the set was powered on & functioning normally, then abruptly changed to what appears attached below. I do not recall any odd noises (crackling, popping or anything of the like). Upon examining the internal boards I found no bulged capacitors.
    Currently I am without a DMM.
    From what I've scoured & collected from other forum posts has me questioning as to whether or not the issue may lay in the PSU, but honestly I am not sure where to head from here.
    Any opinions or assistance would be greatly appreciated.
    Thank you in advance for any help you may relay to my cause.
    I will provide any additional information, if requested, to the best of my abilities.
    Sincerely,
    HamSa1ad
    Image Attachment Key:
    1. Full-shot of display, powered on with an active input, prior to the swap of the X-main
    2. Full-shot of internal boards. I do have close-ups of each individual board if requested.
    3. Full-shot of display, powered on with an active input, post swap of X-Main.
    4. Full-shot of display, powered on with an active input without room lighting, post swap of X-Main.
    5. Close-up of colored portion of display, from image 4. (^)
    6. Shot of display, powered on with no active input, post swap.
    7. Shot of display, powered on with no active input without room lighting, post swap.
    8. Close-up of colored portion of display (solely image burn), from image 7 (^).
  • HamSa1ad
    • Oct 2014
    • 28
    Re: Samsung PN50C550G1FXZA - Dark Display with ''Sparkles''
    PSU Inkling came from crawling this thread:
    https://www.badcaps.net/forum/showth...t=32175&page=4
    • rccrasher65
      • Mar 2014
      • 626
      I have good working boards for this set if needed, just PM me.
      • HamSa1ad
        • Oct 2014
        • 28
        Thank you but I'm afraid that's not quite what I'm looking for
        • HamSa1ad
          • Oct 2014
          • 28
          Anyone have a chance to lend any perspective to my situation?
            I'd suspect X-main.
            • HamSa1ad
              • Oct 2014
              • 28
              Originally posted by tom66
              I'd suspect X-main.
              Thank you for your reply!
              Could you provide me any information as to how I would go about testing the X-Main (either the replacement or the original)
                You would need a digital multimeter to do that... do you now have one?
                • HamSa1ad
                  • Oct 2014
                  • 28
                  Tom,
                  I will be collecting one from the office today to utilize over the weekend
                    Ok, update us when you get one.
                    • HamSa1ad
                      • Oct 2014
                      • 28
                      I presume this guy will do the job appropriately?
                        That's absolutely perfect.
                        Flukes are good meters.
                        • HamSa1ad
                          • Oct 2014
                          • 28
                          Wonderful,
                          I will be home in approximately 2 hours, then I can begin some proper troubleshooting!
                          Looking forward to working with you further. Many thanks!
                          • HamSa1ad
                            • Oct 2014
                            • 28
                            Okay, I'm home now & I've got the multi-meter with me.
                            How shall I proceed Good Sir?
                              Start by verifying the Vs and Va (approx 200V and 60V) against the sticker.
                              There should be some test points on the power board. Red probe on test point, black on chassis, DC volt scale.
                              • HamSa1ad
                                • Oct 2014
                                • 28
                                Okay, va was at 55.3
                                Vs was at 209.7
                                  Those seem right, but just for completeness, do they match the sticker ratings?
                                    Can you get a CLEAR, FOCUSED image of the board on the right hand side of the panel, connected to the orange ribbons.
                                    https://www.badcaps.net/forum/attach...5&d=1412903159
                                    • HamSa1ad
                                      • Oct 2014
                                      • 28
                                      Yeah,
                                      Sticker shows 209 (206-215) for Vs & 55 (53-57) for Va
                                      • HamSa1ad
                                        • Oct 2014
                                        • 28
                                        The first image is of the X-Main (replacement) that is currently installed in the unit.
                                        The second is the original, prior to its removal.
