Resetting the eeprom on the main board
  • fredrock46
    • May 2014
    • 22
    I came accross this article about resetting the eeprom on the main board by connecting a wire accross two pins on the eeprom and then powering on the TV.
    The article is for Samsung TV's and I'm wondering if it might work on this Vizio SV422XVT TV that I can't find parts for.
    I'll quote the item I'm interested in below and attach a link to the full article.
    "For resetting TV, settings, you needed to remove SoC EEPROM device from TV. But it's not required. In electronic world, if you disable communication of the chip, it counts as removed...
    To do this, all you have to do that feeding (connecting) GND (ground) or VCC (3.3v) to SDA line with little wire... That's all.
    Join VCC and SDA, power on TV and hold about for 20 seconds with the TV powered. It just try to read (wrong) settings from EEPROM, since it cannot read anything, just start with defaults."
    http://wiki.samygo.tv/index.php5/UnB..._Factory_Reset
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • SidneyCanadas
    93C46 and 93C56 EEPROM
    by SidneyCanadas
    I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
    https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
    Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
    06-14-2023, 01:16 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • K212
    Samsung QE65Q700TATXXC is not starting
    by K212
    my Samsung QE65Q700TATXXC has stopped working recently. It worked fine during the morning, and when trying to start it later the same day it just refused to start.
    The standby LED is working, but nothing happens when pushing the power button, other then the LED blinking once. No picture, no sound, no chime, no relay click. I tried a cold start, and other recommended fixes from Samsung. Nothing worked. Then i even tried to reflash the firmware, but nothing happened, not even flashing of the standby led etc.
    I contacted Samsung support who said it is most...
    07-31-2025, 12:45 PM
