Panasonic 50" Plasma and its crazy Stand by voltage...
  • BrightLight2000
    • Sep 2014
    Hello folks,
    So, my TC-P50V10 has a 1 blink code. I checked the voltage of the stand by .. supposed to be 5v and it is 7.44 both on the a board and the power board. A25 and P25 pin 9. What does this mean? I read that if there is 5v voltage it is the A board.. but what if it is more.. same thing? replace the A board?
    Re: Panasonic 50" Plasma and its crazy Stand by voltage...
    Did you use DC volts or AC volts on your meter?
    (You must use DC volts...)
    • BrightLight2000
      • Sep 2014
      Dc
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        Replace IС551 in P board
        • electron_jj
          Panasonic TH-L42D25A checking the PSU output voltage
          by electron_jj
          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
          08-29-2021, 08:13 AM
        • DXseekerMO
          Vizio E400i-B2 missing stand-by voltage
          by DXseekerMO
          I picked up this Vizio E400i-B2 with no stand-by light and diagnosed it with missing stand-by voltage. I found a Power Supply at ShopJimmy, installed it but it didn't work properly. SJ refunded the transaction and did not ask me to send the board back.
          So I took some voltage readings upon the original board. Here's what I found:
          Main caps have 169.9v
          AC detect voltage is 1.3v
          None of the MOSFETS appear to be short.
          The opto (IC106) that appears to have something to do with stand-by voltage has 3.0 volts on terminal 1...
          10-30-2021, 10:19 PM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
        • jaroslav.psenicka
          Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
          by jaroslav.psenicka
          I have a Lenovo Yoga 13 Panasonic here, when powered
          • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
          • most voltage rails seem OK (see image below, red labels)
          • resistnace to ground mostly seem OK as well (blue labels)
          the only suspicious is the 0.0V rail (2nd from left, top row)
          • the resistance to ground is rather low (1.9ohm)
          • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
          also tried new BIOS, no change
          I can't find a schematics for the board - can some of you gurus look at the voltages?...
          05-02-2024, 05:59 AM
