Panasonic P50U50 was blinking, but now won't?
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    This one really has me stumped...
    The panel is completely broken, and power LED had been doing the 7 blinks every time I tested it.
    Finally got around to taking the back off today, to see what parts I could salvage. I was confused on which board was the SU, and temporarily disconnected power to the SS board, and then the SS board data ribbon instead.
    So, I reconnected everything as it was, twice, and now it seems no matter what, the relay will just click once. I can see the mainboard optical out light up briefly, and then shutdown. No blinks at all Disconnected SU, and same results.
    Could I have possibly burned the power supply by just unplugging, and then plugging back in?
    On a side note, I was a bit "shocked" to see the small power plugs going to the SS and SD boards still hold some kind of charge even after unplugging. There was an arc 2-3 times trying to plug those back in (too quickly I guess?). I thought these modern power supplies had some sort of drain mechanism on the capacitors, but I guess not? Hope it's not enough juice to give me a heart attack
    Thanks for any ideas on this one. I'm going to try leaving it unplugged for awhile, but I'm not sure that will help.
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Re: Panasonic P50U50 was blinking, but now won't?
    Any ideas on this one?
    Should the set power on if I unplug everything from the PSU except the mainboard? Just trying to narrow down the problem...
    • tw2005
      • Oct 2011
      • 6458
      7 blinks I would expect with cracked panel.
      You may have spiked the A board or SS?
      So what are we talking here, locked solid stdby led or no stdby led at all?
      I don't have a manual for this so hard to know what's what but some of these have the key panel routed via the c board.
      i guess at this stage you want to see an attempted startup with error blinks?
      try disconnecting sc20,sc2, ss11, p35 and see if anything changes.
      If I was testing this, I would have disconnected the sd/u and jumpered sc50 but cracked / possibly shorted panel, risk of damaging c and SS boards.
      Not something I've been faced with. maybe meter out the Sc2 and SS11 connectors and see if there's low ohms, test all the IGBTs for short cct.
      Normally i'd suggest disconnect sc2, ss11, 3 white ribbons at the A board, p35 and try to turn on but if that keypad is routed via the c, nothing will happen.
      • tucocaps
        • Apr 2013
        • 331
        • United Stated
        Thanks again TW!
        I think I was again confused while working on this set. It is indeed throwing the blink codes, but I forgot that I have to push the power button after plugging in to make it do that.
        So, I have 7 blinks. If I disco the couple of small vertical white plugs going to the SC board, I still get the 7 blinks.
        With Panasonic and a cracked panel, and assuming the panel is the root cause of the 7 blink code ... could I simply disco all the panel connection ribbons from the left and right side? I'm trying to see if there is any way to isolate the panel and find out what "good" boards I might have.
        • tucocaps
          • Apr 2013
          • 331
          • United Stated
          Doing more tests, the only thing I've found that I think may be helpful...
          Disconnecting SU/SD , or one , or both, yields the same 7 blinks.
          Disconnecting SC causes a distinctive short higher pitched buzz upon pushing the power button , that I do not hear when it is connected. I *think* the sort of buzz you'd hear when the unit is powering on. It then quickly powers off and throws 8 blinks (instead of 7).
          I've tried many other combos of disconnecting SS, etc. but none seem to show any unique results.
          Is this a main board issue, or would I need a working SC in order to say for sure?
          Also, I'm still wondering about completely disconnecting the broken panel. Can having it connected cause any troubles with the SOS codes?
          • tucocaps
            • Apr 2013
            • 331
            • United Stated
            ... and yes I do realize I said in a previous response that I get 7 (instead of 8 blinks) when SC is disconnected. Not sure on that, or if it is doing both at random? I know the buzz is there when SC is disconnected, but with everything else connected.
            • tw2005
              • Oct 2011
              • 6458
              some light reading for you. sc20 disconnected throws 8 blinks, bad sc or buffers / panel 7 blink, disonnected buffers 7 blink whichis why I suggested sc50 jumpered with the buffers removed, disconnected panel from ss 8 blinks.
              • tucocaps
                • Apr 2013
                • 331
                • United Stated
                Thanks again. Getting there I hope
                I just found the SC50 jumper and jammed a mainboard jumper in there. Still 7, but I didn't disco the SU/SD. Going to try that next. I'm assuming you mean do that, and if 8 blinks, then also disco panel from SS and power again.
                • tucocaps
                  • Apr 2013
                  • 331
                  • United Stated
                  Woo hoo! Got a power on with SC50 jumped, SU/SD disco'd, and everything else connected.
                  I can actually see the power led's now on SC and SS. Only problem I've not seen before... set has a really loud buzzing noise coming from it. Sounds like the one I described earlier, but now constant. Is that just noise from the cracked panel? Having trouble locating the source.
                  • tucocaps
                    • Apr 2013
                    • 331
                    • United Stated
                    Definitely sounding like panel noise. Louder at front, and sort of oscillates in tone.
                    With the SC50 jumped, and power staying on, would this mean SC and all other boards except SU/SD are likely OK?
                    • tw2005
                      • Oct 2011
                      • 6458
                      yes, panel is shorted, you'll have to get a multimeter to check the buffers. if the tv was on when the panel shorted, i'd expect shorted buffers. i've purchased 2 complete boardsets from 2010 series with cracked panels, both had shorted sd boards.
                      if the tv stayed on then it's detected no errors.
                      that is the best i can do for you.
                      • tw2005
                        • Oct 2011
                        • 6458
                        Mate, it has a shorted panel, it passed startup, turn it off and move on before something else fails.
                        • tucocaps
                          • Apr 2013
                          • 331
                          • United Stated
                          thanks again TW! I tested one of the HDMI inputs for sound, and it worked. Unplugged after that , and will be stripping it soon. I'm assuming I'm good to go on all but the two buffer boards, and I don't like keeping those around from cracked panels anyway Too much bad luck with them...
                          • Andre Gilbert
                            by Andre Gilbert
                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                            11-20-2024, 08:52 PM
                          • nobbnobb1
                            Panasonic TC-P50U50 Powers Off - 8 blinks
                            by nobbnobb1
                            I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                            2x DG302 (Q16051)
                            2x RF2001 (D16041)
                            2x 5.6 ohm SMD resistor
                            1x BD8694 IC
                            I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                            03-21-2023, 08:33 PM
                          • jm1234
                            Panasonic plasma TX-P42ST50 - 6 blinks
                            by jm1234
                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                            I checked that board for any obvious faults...
                            05-22-2024, 06:59 AM
                          • riparo
                            Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
                            by riparo
                            Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
                            I attach a link to download the service manual, thank you for anyone who can help me
                            https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
                            01-11-2024, 12:35 PM
                          • Alicat
                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                            by Alicat
                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                            Model number is TH-50PZ85U
                            Power comes on and the red power light stays on solid.
                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                            I also hear a few clicks.
                            I also think my parents said there was a thunderstorm and the TV failed after that.
                            Section 6 in the service manual talks about power and no screen,...
                            10-30-2024, 10:09 AM
