Philips 42PFL9603 2 Blinking leds.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hi People ,
    I got a Philips 42PFL9603D and when i turn it on the power led blinks 2 times.
    I bought this tv from a dude that probably tried fixing this tv by himself ( which i found out later ).
    I already tried a reset but it didn't work.
    On first sight the power board seems to be ok , no bad caps or soldering.
    The main board however has a few issues. When i first opened the back of the TV i though that a few caps were burned out but later i found out that that guy tried to desolder/solder some caps.
    I have NO idea if the caps on the main board are the original caps but the guy really f*cked the board up. ( bad soldering , some pads almost gone )
    The serial nr on the main board = 3104.303.51026 3104.313.62146
    I couldn't find a schematic for this tv on the internet so i can't check the original values. Can someone tell me the values? Im talking about the small grey capacitors. Values of the caps 3x 250/25v and 2x 10/4V.
    So basically my first question is , what are the values and what causes the 2 blink error?
    Thank you for the help and sorry for my english!
    Mark
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    Re: Philips 42PFL9603 2 Blinking leds.
    Сhassis Q529.1E the error 2 times - probably defective SSB
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Thanks a lot for the reply! Any chance how i can figure out what causes the problem?
      • kasfamily
        • Aug 2014
        • 765
        • Russia
        Show photo SSB and PSU board
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • spantor
          Activate power board Philips 40PFH40009/88 tv
          by spantor
          Hello partners.
          Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
          The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
          02-11-2024, 05:07 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • silikon77
          Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
          by silikon77
          Hi!
          Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
          Found some advices watching youtube nad came up with this:
          It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
          I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
          See attached picture.
          I tried a few combinations to block individual clock...
          01-02-2025, 02:26 PM
